586,113 active members*
3,118 visitors online*
IndustryArena Forum > Hobby Projects > Hobby Discussion > Wiring a simple air compressor
    Sep 2017
    An air compressor with model: IV5076055 (From Industrial air USA) is at up front. I can't find information about HP on the manual for wiring purpose. The data at disposal is:
    60 gallon Vertical
    175 Max PSI
    15.3 CFM @ 100 PSI
    13.5 CFM @ 175 PSI
    5.0 RHP
    Any help/suggestions on wiring?
    Nov 2012
    1267
    Re: Wiring a simple air compressor
    Quote Originally Posted by Antip View Post
    5.0 RHP
    I would use a 4mm (diameter) wire and a 32A breaker.
    24221
    The link says 5HP, the manual does not give any details on wiring connections except 230v and 'refer to the motor plate'!
    What exact info are you looking for?
    Al.
    Albert E.
    I usually use strings 6mm
