586,075 active members*
3,993 visitors online*
    Sep 2015
    11
    Calculate steps/mm
    I really need some help. I might have been able to figure this if I didn't have to go back and forth between metric and imperial measures.
    I am trying to figure:
    steps per mm = steps per rev * microsteps / mm per rev
    My motor is nema 23 and 200 full steps per rev
    I have a cnc=shield with jumpers set to 1/32 (I think) M0, M1 and M2 are high
    Leadscrew is 5/16 -18
    Any guidance would be greatly appreciated.
    Jun 2008
    128
    Re: Calculate steps/mm
    its better to think through the logic than remember a formula.
    1 revolution takes 200 * 32 steps = 6400 steps/rev
    1 inch movement takes 18 revolutions = 18 * 6400 = 115200 steps/inch
    1 inch = 25.4 mm so 1 mm = 115200/25.4 = 4535.433 steps per mm
    Sep 2015
    11
    Thanks a million George! You made it look easy.
    Sep 2015
    11
    I've just been wondering if I might have an easier time with cnc'ing if I quit trying to do a little bit in Imperial and a little in metric. Maybe If I just concentrated on metric it would keep the water a little less muddy. The tough part is just trying to visualize a millimeter.
    Jun 2008
    128
    I know how you feel having worked in imperial for past 70 + years I don't think metric I convert metric to imperial to visualize.
    You can set your CNC up in imperial and to machine metric just put a G21 code at the start and your machine will do the conversions. Just remember 100"/min = 2500 mm/min
    The more you work with metric the easier it gets.
  1. C6B Calculate steps for Mach3?
    By john_t_h in forum Syil Products
    Last Post: 11-07-2008, 05:46 PM
  2. Procedures to calculate steps per inch
    By DrStein99 in forum LinuxCNC (formerly EMC2)
    Last Post: 08-17-2008, 01:53 PM
  3. Calculate "Steps Per" In Motor Tuning
    By Burn in forum Mach Mill
    Last Post: 05-16-2008, 03:25 AM
  4. how do you calculate steps
    By cp465vw in forum Benchtop Machines
    Last Post: 11-27-2007, 11:36 PM
  5. Proper way to calculate steps/unit for belt drive?
    By MrBean in forum DIY CNC Router Table Machines
    Last Post: 03-31-2007, 03:48 AM
