Hi, Thanks for your reply. I haven't had any success as yet. Any help would be very much appreciated. Are you in Brisbane?
Hi Maki,
you should be able to access the ip address by going to f6 parameters, then it may show f2 or f3 network settings. If not you need to press F6 parameters, then f10 then it will show the network settings.
What version of windows are you running on your office pc, as network and sharing settings need to be changed as well.
Ok. I will try that. I have followed the steps in this video: https://www.youtube.com/watch?v=im4JK88PFN0 But can't change the name on the controller (around the 3.30 mark) I'm running windows 10.
You will be able to change the pc name
First you want to select static IP address on the controller (not via DHCP)
Then check what the IP address is on your office pc (for example 192.168.1.3)
You then want to make the ip address on the cnc 192.168.1.50 (last number can be anything but no higher than 100)
arrow key down to the pc name, this needs to be the pc name of the office computer
then arrow key to the DIR, this needs to be the folder name of the files folder that will be on your office pc. (i.e create a folder in the C drive - Woodtron. you will place all the cnc files in here)
this woodtron folder will then need to be shared and network sharing settings need to be set correctly on the office pc.
Ok, thank you.
I believe I have set up the info on the office pc correctly, or can adjust it easily enough.
Accessing and changing the info on the syntec is harder. The controller in that video is different with a slightly different menu setup etc.
This is mine: https://www.dropbox.com/s/8pvod0qq7r...%20pm.png?dl=0
Can you ping the CNC via the office PC?
good
Dir Name needs to be the folder name on your c drive, in this case - cnc
once entered press F1 ok. turn the controller off and on again.
Ok. I have plugged router into switch. cnc ethernet cable into switch and office pc connected wirelessly - or does that need to be plugged in via ethernet too?
