586,449 active members*
3,394 visitors online*
    Mar 2004
    1543
    Servo Amp Faults
    I'm using an Advanced Motion Controls PWM servo amp on my Hardinge CHNC lathe.
    I'm having trouble with a drive fault on the Z axis. At first, I just lowered my acceleration and max velocity. Problem is getting worse.
    Can anyone explain what the drive sences to light the drive fault light? And, likely problems to look for.
    Manual attached.
    Karl
    Attached Files Attached Files
    93
    Try swapping the module to the other axis and see if the problem moves too.
    There are plenty of those on ebay. Could be the motor brushes or tach also.
  1. Servo drive / Servo Amplifier
    By Ken_Shea in forum Servo Motors / Drives
    Last Post: 07-10-2007, 11:12 PM
  2. pm feild servo servo
    By eloid in forum Servo Motors / Drives
    Last Post: 03-03-2007, 11:27 PM
  3. VFD drive Faults on series I cnc Bridgeport
    By colin1544 in forum Bridgeport / Hardinge Mills
    Last Post: 09-22-2006, 11:36 PM
