586,119 active members*
3,707 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Need help connecting usb to VSD-e drive
    Nov 2007
    66
    I have done this procedure in the past, but I am old and forgot. I am using the special usb cable with the six wires that plugs into the drive. When reading the GDtool manual, load GDtool and to connect, turnoff signal power and then turn on. Is the signal power in the 16 wire connector? I will be checking parameters without HV connected. Like I say, I forgot, please help, Robert Brown.
    Feb 2007
    4553
    Re: Need help connecting usb to VSD-e drive
    Robert,
    IN3 is Pin 10 of the CMD connector.
    Have a most awesome holiday!
    Jeff...
    Quote Originally Posted by machining fool View Post
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Nov 2007
    66
    Thank you very much, I figured out. As soon as connected the 16pin connector, I got connectivity. I also found that the max. voltage setting was 105000mv. should have been 170000mv. and this change might solve my problem with an over voltage red and blue light flashing occurance, thank you Bob.
    Nov 2007
    66
    OK, all es well. Evidently I had a bad drive. Put another in and put parameters in, and everything seems to be OK. Thanks, Bob.
  1. poblem connecting servo drive to mach3 motion control
    By qussai in forum Servo Motors / Drives
    Last Post: 06-26-2016, 06:38 AM
  2. Problems connecting to viper 200 drive
    By Scrambled1 in forum Viper Servo drives
    Last Post: 02-28-2015, 10:01 PM
  3. Replies: 2
    Last Post: 06-23-2014, 07:59 AM
  4. Connecting Emerson Drive SK to Mach3 Program
    By fishin_fl in forum Mach Software (ArtSoft software)
    Last Post: 02-23-2013, 01:59 AM
  5. Connecting two identical drivers to drive one stepper motor?
    By uplb in forum Stepper Motors / Drives
    Last Post: 11-24-2008, 04:13 PM
