588,130 active members*
5,007 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > Reading the end of my post processing G Code
Results 1 to 13 of 13
    Nov 2017
    10
    Hello. I'm trying to find out how to read my post processing text to identify where my machine will come to a stop after milling. How can I read it and identify that? I've only had a cnc for about 6 months and I have very limited time reading G code. Hoping to learn more but need to know this. Thanks for your help.
    Dec 2013
    5722
    Re: Reading the end of my post processing G Code
    Why don't you post the last few lines of your G code file and maybe we can help you.
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2006
    1792
    Search for M02 and M30 which terminate the program.
    Nov 2017
    10
    Thanks for the replies. This is the last lines of the post. I see M30, but...? Not sure what M30 is saying. I thought that I read that maybe G28 says to go to home? Not sure if I'm reading that right, but if so, can I replace that to read G54, which is my part zero and where I'd like it to end? Sorry I'm not very familiar yet.
    X13.2064 Y9.3904 Z-0.6407
    X13.2034 Y9.3876 Z-0.6426
    X13.2002 Y9.3846 Z-0.6439
    X13.1969 Y9.3816 Z-0.6447
    X13.1936 Y9.3785 Z-0.645
    G3 X13.1875 Y9.3651 I0.0131 J-0.0141
    G1 Y8.1715 F100.
    G3 X13.1909 Y8.1572 I0.0375 J0.0013 F39.4
    G1 X13.1927 Y8.1531 Z-0.6447
    X13.1946 Y8.1491 Z-0.6439
    X13.1964 Y8.1451 Z-0.6426
    X13.1981 Y8.1414 Z-0.6407
    X13.1997 Y8.1379 Z-0.6384
    X13.2012 Y8.1346 Z-0.6356
    X13.2025 Y8.1317 Z-0.6324
    X13.2037 Y8.1292 Z-0.6288
    X13.2046 Y8.127 Z-0.6249
    X13.2054 Y8.1253 Z-0.6208
    X13.206 Y8.1241 Z-0.6165
    X13.2063 Y8.1234 Z-0.612
    X13.2064 Y8.1231 Z-0.6075
    G0 Z0.6
    M9
    G28 G91 Z0.
    G28 X0. Y0.
    M30
    Feb 2006
    1792
    You would need to read a text book.
    M30 terminates the program and resets the control.
    Nov 2017
    10
    You're right about that. I do need to learn to read this stuff better. Am I right about G28 though? When you read the end of the post that I included, what do you see M30 telling you? Sorry I don't have time to read a text book right now but I work too much and have a 7 month old that I have to pay attention to, so my time is somewhat limited. Any help understanding this will be appreciated.
    Dec 2013
    5722
    G0 Z0.6 (moves Z to a safe location)
    M9 (turns coolant off)
    G28 G91 Z0. (G28 - go home) (G91 - set incremental moves) (move Z to home 0)
    G28 X0. Y0.
    M30 (program end and rewind) (rewind is from the old tape drive days) (M2 also means program end, with no rewind)
    https://www.cnccookbook.com/g28-g-code-cnc-return-reference-position/
    By adding any G code you want after the cutting moves, you can park your machine anywhere you want.
    Example:
    G0 Z0.6
    M9
    G0 Z1.0 (rapid Z to 1.0 unit)
    G0 X10.0 Y10.0 (rapid X and Y to 10.0 units)
    M30
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2017
    10
    Thanks for the info Jim. So can I just remove this entire section:
    M9
    G28 G91 Z0.
    G28 X0. Y0.
    M30
    Replaced with:
    G55
    This is where I have my part zero setup and where I would like to have the machine come to rest and turn off.
    Dec 2013
    5722
    I have never used work offsets so I can't really answer that question. But don't forget the M30 at the end.
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2017
    10
    Sorry if I'm being dense, but just to make sure I'm thinking about this properly, M9 turns off the coolant, from what I can understand G28 sends the machine HOME, and M30 basically turns the power off or something along those lines? What does G91 do?
    M9
    G28 G91 Z0.
    G28 X0. Y0.
    M30
    Dec 2013
    5722
    More correctly M30 tells the controller that it's at the end of the program.
    G91 sets the coordinate system to incremental moves. Seems like an odd place to have a G91, but Fusion is a little weird sometimes. I know you can turn off the G28 in Fusion, I think it's a checkbox in the setup. Or you can edit the post processor and set Use G28 to False if I remember correctly.
    This might be helpful to you
    https://en.wikipedia.org/wiki/G-code
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2017
    10
    Thanks for the link. I have been checking that out a bit. I think I have a small grasp on this now. I really appreciate you taking the time. Had my machine crash into the end in the Y direction wednesday night, I'm thinking from those command lines, and it's been running inaccurately since. Trying to get it squared up and running smoothly again and also trying to eliminate the chances of it happening again with the command lines.
    Dec 2013
    5722
    My pleasure to help where I can
    You proabaly need to loosen what ever bolts attach the Y axis, square it up and retighten. I've had to do that with a couple customer machines when they had problems. Hopefully that will fix that problem then you can make adjustments to the G code so that it behaves.
    Jim Dawson
    Sandy, Oregon, USA
  1. Mach3 reading fusion 360 g-code as error
    By mcdoggie in forum Machines running Mach Software
    Last Post: 08-10-2017, 05:49 AM
  2. G-Code is not processing/running correctly or at all
    By Seeders in forum Multicam Machines
    Last Post: 06-25-2015, 05:22 PM
  3. Plasma G-code reading
    By silon132 in forum Waterjet General Topics
    Last Post: 10-30-2008, 01:45 PM
  4. haas vf-4 mill not reading code
    By WhiteZee in forum Haas Mills
    Last Post: 06-09-2007, 08:53 PM
  5. Any Way to Improve Processing G Code with Excel?
    By keithorr in forum G-Code Programing
    Last Post: 06-21-2005, 08:29 AM
