587,245 active members*
3,198 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Help selecting air cylinder for power drawbar
    Jul 2015
    I'm planning on adding a power drawbar to my Sieg X2 mill.
    I've been looking at Hoss design and am thinking of build one similar to that one.
    However, I'm having trouble finding an air cylinder and am not really sure what specs to look for.
    Could someone please help me find one, preferably on eBay or Amazon.
    I've been looking at this one, will this do?
    https://www.ebay.com/itm/MAL-25-x-25...YAAOSwnw9Z6XdN
    Nov 2009
    4415
    Re: Help selecting air cylinder for power drawbar
    Unlikely that one will work unless you are using 1 of his later designs. The later one had a lever and cylinder. The first that I remember was a triple stage cylinder.
    The triple puts the pressure directly downward. You would just calculate your available air pressure, the force needed to overcome the belleville's and find which cylinder will apply that kind of pressure.
    Personally I would go to Fabco's calculator and see which cylinder they would recommend.
    A lazy man does it twice.
    Jul 2015
    I have been looking at the design where he has a cylinder of a similar size with a lever.
    I'm not sure what specs the cylinder needs to have
    Skickat från min iPad med Tapatalk
    Feb 2018
    8
    Same here...after looking at several designs I think using one or two smaller actuators (like your link) and a mechanism using a lever to gain the advantage is the way to go. This is the way I plan to try anyways
  1. 30Taper YCM30 Drawbar or power drawbar options.
    By countryguy in forum Knee Vertical Mills
    Last Post: 12-28-2014, 06:15 AM
  2. High Tension Power Drawbar Using 3in Cylinder
    By LacL in forum Benchtop Machines
    Last Post: 08-14-2014, 01:39 AM
  3. Milacron 15VC machining ctr drawbar cylinder
    By ganzelc in forum Cincinnati CNC
    Last Post: 01-01-2011, 05:46 PM
  4. Help Selecting a Power Supply
    By millman52 in forum CNC Machine Related Electronics
    Last Post: 01-19-2008, 08:05 PM
  5. Help selecting a power supply
    By Hack in forum CNC Machine Related Electronics
    Last Post: 02-28-2006, 03:35 PM
