586,115 active members*
3,372 visitors online*
    Jun 2010
    Mazak SVC-2000 Mystery Noise
    The other day one of our operators went to home out the SVC-2000 right after start-up. He uses the multi axis button to home out, and all move about the same time. A second or so after the machine began to move, an extremely loud, vibrating/grinding noise came from somewhere in the inside of machine. I wasn't there, but the whole shop heard it and all agreed it was "Very Loud" everyone thought he crashed the spindle hard! There was no alarms other then the machine went into E-stop mode. we powered Off/On and all is fine...The machine hasn't done it since. Has anyone encountered anything like this or know what might be happening here? The ball screws and bearings sound fine. Also, it was so intense I guess the nearby operators could feel it vibrate.
    Sep 2017
    139
    Re: Mazak SVC-2000 Mystery Noise
    Can you check if the aflt value in servo diagnosis page. If the same is fluctuating then you might have to adjust the notch filter frequency parameters
  1. Mazak MYSTERY. HOW do you clear this ANNOYING Mazak alarm??!!! NOBODY KNOWS!!
    By Mill&Lathe in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-03-2022, 01:55 AM
  2. Mazak QT35 NOISE
    By beto81 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-01-2018, 07:41 PM
  3. 2000 Mazak FJV-200 thoughts
    By skyler olsen in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-27-2013, 05:25 PM
  4. Mystery Spindle Noise (watch video)
    By akedward in forum Haas Mills
    Last Post: 04-19-2009, 05:21 PM
