586,108 active members*
3,130 visitors online*
IndustryArena Forum > CAD Software > Rhino 3D > Pasting into command line works with single line pastes, but not multiple
    Dec 2017
    8
    I am having trouble executing while pasting into the command line.
    When i paste these commands ( attachment: create box.txt ) into rhino it does not work as i expect.
    Desired: If i run commands from file or copy/paste the whole contents: only one box is created (attachment: only one.jpg)
    What i get: If i copy / paste lines one-by-one:the complete model (complete box.jpg)
    This was working before to create whole model with one paste, and i don't know what changed.
    Rhino 3D:Version 5 SR14 64-bit(5.14.522.8390, 2017-05-22)
    Win10 pro - 64 bit, fall creators update.
    Thanks for the help.
    Attached Files Attached Files
    Dec 2017
    8
    Re: Pasting into command line works with single line pastes, but not multiple
    anyone have any clues as to what could be going wrong? I changed line endings but there was no change.
    Dec 2017
    8
    The problem has to do with material references. Specifically that the rhino materials were not embedded into the file. No script command is available to embed them.
  1. Command Line Script
    By emiemi in forum G-Code Programing
    Last Post: 05-03-2016, 02:50 PM
  2. command line control
    By wjfiles in forum Mechanical Calculations/Engineering Design
    Last Post: 06-04-2006, 01:11 PM
  3. Single line mode works well, Auto is not soo good??
    By Darc in forum CamSoft Products
    Last Post: 10-26-2004, 09:29 PM
  4. Line command
    By cncadmin in forum Uncategorised CAM Discussion
    Last Post: 06-26-2003, 08:42 PM
