I was routing some Versatex PVC today & I could hear the router slow a little then stopped. The table continued to run. I reset everything & still nothing.
I removed the router plugged it into the wall & nothing. The bit spins freely without slop. The router is a Porter Cable if I remember it's a 3.5hp.
I would love to replace / upgrade the table in a year or so once I get using it more & can justify it. The table design (Machine Comp) now that I know more about routers the table leaves a lot to be desired.
So my questionsare this,
1. Can it be repaired or does it need replaced?
should I get a new hand held router & replace the existing one.
2. If it needs replaced should I replace it with another Porter Cable or another "regular" router or should I purchase a cheaper Chinese spindle?
Any help is greatly appreciated
Thanks in advance
