586,058 active members*
4,549 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > VM16 w/Centurian 6 Z axis Problem
    Mar 2007
    207
    I am running a vm16 that dosnt like tools to be left in the spindle at program end.I try to load the first tool needed ind the program at program end to save startup time. If I start up with a tool in the spindle the Z axis goes positive agenst the limit switch. The program end is written as follows:
    N9900 (program end)
    M05 : spindle off
    G00 X2.600 Y2.000 : Begining spot
    T12 M06 : Select 3/16 end mill & its length of offset
    D12 G43 H12 : set nose dia. & length of offset
    M30 (end of program)
    Apr 2004
    124
    What does the beginning of the program look like? Todd
    Jan 2007
    206
    are you programming in conversational or g code?
    The Farmer
    Mar 2007
    207
    VM16 Z Axis
    I have the VM/16 back up and running but still wonder why it was having a fit.
    The program was blocked stepped up to the point of the problem but it makes no sense. The program reads as follows: N2000
    G00 X2.600Y2.00
    T12 M06
    D12 G43 H12
    M08
    S2200 M03
    The failure was at G00 X2.600Y2.00 .When this line was moved down past the tool change the problem went away. also if the tool change was removed from the last program block there was no problem. Why would an X,Y or tool change affect the Z axis ? Thanks for the help
    Mar 2006
    370
    It sounds like a flag is set when the "H" command is executed. Then when the next G00/G01/G02/G03 command is executed and the flag is set, the previous offset is completely incorporated. End the program before a move command is executed and the flag is cleared. This leaves the controller in a strange state.
    At least you found a work around.
  1. tree 220 with centurian v controller
    By tractorguy in forum Tree
    Last Post: 12-07-2006, 10:00 PM
  2. Problem with Z axis
    By MagTDK in forum DIY CNC Router Table Machines
    Last Post: 11-01-2006, 03:12 AM
  3. Problem with 4th Axis Plotting
    By TURNER in forum NCPlot G-Code editor / backplotter
    Last Post: 10-19-2006, 12:35 PM
  4. z axis problem
    By UMASSREHAB in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-29-2006, 11:45 PM
  5. Z-axis problem
    By Trainhound in forum DNC Problems and Solutions
    Last Post: 12-14-2005, 09:24 PM
