586,103 active members*
3,547 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > NEED TO PROBE A BORE WITH MORE THAN 4 POINTS WITH RENISHAW PROBE
Results 1 to 9 of 9
    Dec 2006
    116
    I would like to be able to probe a bore that is egged to find the average center of the bore. The issue is that I cant find a probing cycle that will allow more that 4 points. Is there any help out there?
    WANNA GO FASTER
    Jun 2015
    Re: NEED TO PROBE A BORE WITH MORE THAN 4 POINTS WITH RENISHAW PROBE
    Do a one point probe cycle, load the touch into a variable
    Do this for as many touches you want, loading each touch into a separate variable then calculate the average of the variables.
    Dec 2006
    116
    Quote Originally Posted by 840DPROGRAMMER View Post
    Could you please show me an example of the written code?
    WANNA GO FASTER
    Mar 2017
    314
    I dont see any way to take single hits with a vector cal probe.Much less stitch those points together into a circle. It would have to be vector calibrated to take hits in a non-orthagonal direction.
    I would argue that the 4 hit bore boss cycle IS giving you the average/centroid of the bore.
    Mar 2017
    314
    you can run 3 point bore, store that position. run it again 180 out and average the positions. Still have to vector calibrate
    Dec 2019
    Post an example of the code your orthagonal probing cycle uses and I should be able to help with this... what software is your probe running from easy set, mazatrol, etc etc?
    I see 840D in your username.. the siemens controllers I have no experience with, but I believe they use a conversational user input that is translated to g-code type programming similar too how say the old okuma IGF worked??
    Jun 2015
    4154
    hi, for probing more than 4 points inside a bore, or, for contact points at angular positions <> 0 90 180 270, it is required a probe ( and software ) that is sensitive to cosine directions, thus can detect if the contact surface is perpendicular ( or not ) in respect to feed direction / kindly
    Jul 2005
    380
    If the Probe was factory installed, the Inspection plus software is in the machine. The macros are as well, so you can give it the macro commands as needed.
    Jan 2020
    12
    I'd imagine you might be able to run the M165 probe bore cycle, store the results in a second bank of open macro locations, then G68 or rotate the machine coords 45 degrees and run a duplicate cycle.... likely then sort thru the 8 results for an out of tolerance condition?
  1. WANT TO PROBE BORE WITH MORE THAT 4 POINTS WITH RENINSHAW PROBE
    By metlshpr in forum Calibration / Measurement
    Last Post: 12-15-2017, 06:09 PM
  2. TP-100 Probe - Compare Performance Motion probe to IMService probe
    By dgoddard in forum Digitizing and Laser Digitizing
    Last Post: 04-06-2013, 07:13 PM
  3. Mp7 Renishaw probe
    By Cncjunkie in forum CNC Machining Centers
    Last Post: 02-02-2006, 04:13 PM
