Originally Posted by
Sterob
I'm not that experienced but I'll have a go....
Did you get a 'Quickstart' document with the router? If you did, that should get you up and running.
Do you need a plugin for the USB card? ( if you do it will be an '.ini' file ). My X61500GT does. Not sure what the X6-2200L uses.
It sounds like Mach 3 is doing its job. Its just that Mach3 can't 'see' your USB motion card, or your Outputs in Mach 3 are not configured yet. Have you done that?
'Emergency Stop' button is disabled?...you have bypassed it or it is pushed in?
Unfortunately it only takes one incorrect step or setting to keep it from working.
Steve
