586,117 active members*
3,470 visitors online*
IndustryArena Forum > CNC Electronics > Viper Servo drives > Viper 200F Has Short Circuit Fault but Manual says nothing about a fix????
    Feb 2008
    216
    My Z ran into the limit and was shut off abruptly. The Viper is now showing 8 blinking lights which is the Short Circuit Protection.
    I've changed fuses, shutting it down, nothing will reset the protection. The manual doesn't say what to do. It can still connect to the Hyper Terminal like normal.
    Has anyone had this issue? Anyone know what to do to get it back up and running? Is there something I damaged that i should look for?
    Feb 2008
    42
    Re: Viper 200F Has Short Circuit Fault but Manual says nothing about a fix????
    Did you disconnect the limit switch wire to make sure it isn't a reed switch issue?
    Need a Supermax YCM-40 Mill manual? Download the PDF here (replace _ with .):
    http://www.istonline.ca/download/supermax-ycm-40.pdf
    Feb 2008
    216
    We have 4 vipers. We disconnected it and ran the other 3 just fine. When we put it back in it wouldn't work again. We contacted Viper and they are going to repair it based on the blinking lights they thin it's a damaged Mosfet.
  1. Short Circuit I think???
    By katerina4 in forum EDM Discussion General Topics
    Last Post: 12-08-2017, 11:22 AM
  2. REGULATOR SHORT CIRCUIT
    By Arjuna in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 04-05-2013, 10:13 AM
  3. Tuning Viper 200F
    By Trucks in forum Viper Servo drives
    Last Post: 09-07-2012, 02:01 PM
  4. Short circuit protection
    By Beaker in forum CNC Machine Related Electronics
    Last Post: 10-07-2009, 12:16 PM
  5. Short circuit question
    By Tomax in forum CNC Machine Related Electronics
    Last Post: 04-30-2008, 03:46 AM
