586,102 active members*
2,606 visitors online*
Results 1 to 7 of 7
    Jul 2006
    130
    Machine storage
    This is a little generic but I have a question for the guys with machines in their garages.
    Is their anything special that needs to be done to protect the machines? I'm looking at a partner 1 and it would need to be setup in my detached garage.
    Mar 2004
    1543
    Re: Machine storage
    Number one thing is watch for times of the year when air dew point or humidity can get higher than the temperature of the steel.It will quickly rust under these conditions. Several solutions depending on your location and the building. 1 keep machine oiled. 2 heat the building. 3 run a dehumidifier 4 run an air conditioner
    Jul 2006
    130
    Re: Machine storage
    Thanks Karl, good point, more so with the computer and drive cabinet I can assume? I've had OK luck with my wood working tools which are in a separate area only had one horrible instance of a wild unpredictable swing where everything was coated in water when I got home years ago.
    A side question, what is the height of the machine with the Z lowered and blocked off.
    Trying to work out the last of the logistics in my head. Pass through a standard 7' garage door I'm assuming, but how much room.
    Apr 2013
    28
    Re: Machine storage
    I suspect you've got it figured out already regarding the height but I was on the phone with Sportybob today and he said they'd fit through a 7' door.
    Regarding storage, if you can't run a heater or dehumidifier, dessicant packs can be bought and stored inside the enclosure, or a tray of clay kitty litter can be used to pull moisture.
    Jul 2006
    130
    Re: Machine storage
    Quote Originally Posted by Sooner_CNC View Post
    Thanks for the info. I was just kinda guessing they would fit based on a couple statements but its good to hear it confirmed.
    Good tips on the humidity too. Hopefully soon it will be moved to a controlled building late this year but it'll be in the garage for the rest of the winter/spring/problem season.
    Jun 2010
    4256
    Re: Machine storage
    I bolted a couple of 5 Watt heaters onto my lathe to keep it just slightly warmer than ambient. Seems to work.
    Actually, a couple of 10 W power resistors running at 5 W and mains-driven.
    Cheers
    Roger
    Jul 2016
    660
    Re: Machine storage
    WD40 seems to work here in my humid location, all my metal tools are sprayed with WD40 before storage, and it`s been 3 years now, every time I take a glance on my tool bin they are still sparkling with chrome with no visible rust on it WD40 claims that it will protect metals for two years (24 months) on a storage bin or your money back works as advertised for me hehe
  1. Mazak QT 10N - Wiring Diagram and testing an old machine out of storage.
    By cwtoyota in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-08-2020, 07:54 AM
  2. Beautiful Wood Wine Storage House made by our Rotary Machine
    By Roctech-Cathy in forum Roctech CNC Routers
    Last Post: 08-24-2015, 10:13 AM
  3. Beautiful Wood Wine Storage House made by our Rotary Machine
    Last Post: 08-24-2015, 10:07 AM
