586,096 active members*
3,877 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Torchmate > Need help to identify plug on torch height control
    I have the Torchmate 3 torch height controller box and set up and the torch height doesn`t work properly.
    I bought this machine used and cannot get in touch with the previous owner to ask about the problem I'm having.
    I looked at the owners manual and the wiring is in place on the power supply. (Hypertherm Powermax 1650).
    I noticed a wire plug near the torch that is not connected to anything, just dangling there and I figure this might be the problem.
    I wanted to know if any of you might be able t help me here, thank you
    Re: Need help to identify plug on torch height control
    Thanks anyway, I found out incidentally while searching the manual, it is a plug used for calibration by TM only and not used to actually run the machine and I did, for now anyway, solve the problem we were having with the AVTHC.
  1. DIY Torch Height Control
    By tjb1 in forum Stepper Motors / Drives
    Last Post: 12-21-2016, 05:12 PM
  2. DIY torch height control help
    By mjp in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 11-11-2016, 08:55 PM
  3. THC - torch height control
    By hadacino in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 03-08-2013, 05:14 PM
  4. Torch Height Control
    By Rxe in forum Waterjet General Topics
    Last Post: 04-07-2010, 12:09 PM
  5. Torch Height Control / Capacitive Height Control
    By ahlbebuck in forum Open Source Controller Boards
    Last Post: 11-27-2006, 08:32 PM
