603,923 active members*
2,533 visitors online*
Thread: 4 cylinder
Results 1 to 9 of 9
    Jan 2007
    76
    4 cylinder
    Couple of photos of 25cc water cooled, glow ignition, 4 cylinder that I finished about 12 months ago. Engine will live in 39inch hull of a Chris Craft Rivierra that I am also building. Fuel is methanol at about 5% castor and runs up above 10,000rpm no trouble.
    Other casting is the start of 60cc V8. Will be run on unleaded. Plan for electronic spark ignition with advance retard, oil pump in sump, valley cam. Another is being built here with twin o'head cams.
    Attached Thumbnails Attached Thumbnails DSCF0127a.jpg   DSCF0128a.jpg   DSCF0130a.jpg   DSCF0132a.jpg
    May 2006
    2415
    Sweet work man!!!
    Don't spose you have any video of it running ?
    Russell.
    Dec 2006
    603
    Very nice.
    May 2006
    2415
    I see from your profile you are in Brissie, if it is OK with you next time I am down that way I would like to have a look at your engines if at all possible. I probably won't be there for a good 6-12 months, but no harm in asking.
    I would like to make a multi cylinder 4-stroke to fit to a scale model of a Spitfire, I just can't bring myself to install a 2-stroke engine to a flying model like that, if only for the sound of the engine running. I have seen the scale Merlin engine running, though that is a little out of my league.
    Cheers
    Russell.
    35494
    Very cool to see one of those small motors actually running something, instead of just mounted to a stand.
    Mar 2004
    1661
    Harrrdcore!
    May 2007
    26
    Why is the head divided into, like, 2 or 3 main pieces? Or am i blind?
    Apr 2005
    281
    I don't think you are blind. I may be out of touch but would it have internal coolant passages milled in the centre section. That would be one way for cooling the head.
    John
    Apr 2007
    151
    V8
    Hi Bluejets
    Just seen your pic of V8 block casting, looks interesting. I have recently bought a Syil X3 CNC mill and thinking of bulding a 1/4 size V8. Are you designing the V8, or building to published drawings, could you help with info?
    I built a 1/4 size Bently nine cylinder rotory areo engine a few years ago, am hungry for more punisment.
    Regards
    Mike
  1. Casting a cylinder head
    By hammers in forum Casting Metals
    Last Post: 08-24-2007, 12:22 PM
  2. Rotating cylinder engines
    By CNCgr in forum I.C. Engines
    Last Post: 07-01-2007, 04:54 PM
  3. need duplicate cylinder made
    By blasterboy1980 in forum Casting Metals
    Last Post: 10-30-2006, 03:21 AM
  4. Ford cylinder heads
    By Rockyr49 in forum Community Club House
    Last Post: 01-27-2006, 01:52 AM
  5. Replies: 1
    Last Post: 12-29-2003, 02:06 AM
