586,058 active members*
4,263 visitors online*
    Jul 2012
    6
    Fanuc OT-c Won't Power up
    We have a Hardinge CS-51 that won't power up.
    The display won't come up no button light at all. At first glance we found the red alarm light on the power supply coming on when the power button was depressed.
    We replaced the supply, now no alarm light but still no power. fuses are all ok. I can't reach th test voltages on the power supply because of were it is located.
    I don't have any prints or manuals. I am looking for any of these I can get or advice as to what I can check.
    Thanks for you help.
    dom
    May 2016
    526
    Re: Fanuc OT-c Won't Power up
    Have you checked the voltages in the controller
    Jul 2012
    6
    The location that the Power supply was in didn't allow access to the side where the test points are. But I did find a sketch on the internet that shows the connections in a block diagram. It turns out that our maintenance person had switched the display cable with the on off switch cable.
    Once I corrected them we are back up and running.
  1. Fanuc 6M will not power up
    By Aaronh in forum Fanuc
    Last Post: 07-26-2014, 03:16 AM
  2. fanuc 21 tb does not power up
    By Arvind_sharma25 in forum Fanuc
    Last Post: 08-13-2013, 05:14 PM
  3. FANUC Alpha Series power supply input power limits
    By tcom-frazzled in forum Uncategorised MetalWorking Machines
    Last Post: 01-17-2012, 06:07 PM
  4. Fanuc 3M won't power up.
    By thebighorn in forum Fanuc
    Last Post: 12-12-2008, 11:32 PM
  5. fANUC AUTO POWER OFF
    By BIRDTOOL in forum Uncategorised MetalWorking Machines
    Last Post: 02-13-2007, 12:43 AM
