586,061 active members*
4,506 visitors online*
    Oct 2008
    4
    Dah lih Fanuc 10m Parameters
    Good afternoon everbody.
    First time using this forum so i hope i am at the right place. I have a Dahlih MCV-760 machining center and we have lost the parameters for the machine. It is a 1988 model with a 10M control and it has digital AC servo motors.
    Does anyone have the same machine that can help me out with the parameter? I have tried the agents and they can not help me, I even email Dahlih themselves without any luck
    24221
    Re: Dah lih Fanuc 10m Parameters
    Unfortunately this happens all to often where a CNC machine parameters and options are not saved, at some time in the life of the machine.
    I have had good luck in the past with Dah-Lih but maybe due to the age the records are gone.
    As a last resort you may have to get someone local to reconfigure it.
    There are still a few around so hopefully you can get a copy that way.
    Al.
    Albert E.
    Oct 2008
    4
    Al.
    Thank you Al. Will keep on trying
    Jul 2009
    35
    Hi Jokky. I was in a similar situation a while ago. I bought a TC-10 Taki with 21 control.that was neglected. I sourced all the components and when I eventually got to switching on, the parameters were lost. I spoke to the agents and the applications guys couldn't help me.Taki also sent me to every mail address the have between Japan and Taiwan (why?) About a year ago I slowly, but surely started to strip out the electronics and started a retrofit with LinuxCNC. I am close to the end. With the limited time available to work on the machine, I would have a running machine in about two months.
  1. Replies: 3
    Last Post: 10-22-2020, 09:20 PM
  2. Parameters SL-2, fanuc 6T-B.
    By GPena in forum Mori Seiki lathes
    Last Post: 03-21-2014, 08:55 PM
  3. Fanuc parameters
    By Mehboob ur Rehm in forum Fanuc
    Last Post: 02-28-2012, 09:54 AM
  4. fanuc 5t parameters
    By karolg in forum Parametric Programing
    Last Post: 02-05-2009, 05:12 PM
  5. Help I need Fanuc 3tf parameters
    By lloydy304 in forum Fanuc
    Last Post: 09-28-2008, 10:48 PM
