603,378 active members*
3,140 visitors online*
    May 2013
    32
    new dyn4 autotune
    I have been up and running with a bridgeport boss4 knee mill and dmm dyn4 servos for a few years but I decided to make some tuning adjustments and low and behold there is an autotune function in the latest DMM software.
    Has anyone used this?
    May 2013
    32
    Re: new dyn4 autotune
    It could be my setup but the autotune doesn't work for me. It picks fairly high gains in the first portion way into resonance. Then when it gets to the high acceleration part of the tuning the servos lose a phase.
    15362
    Quote Originally Posted by boss4 View Post
    I'm not sure, if you don't have there new servo drives it may not work correctly on the older drives, there have been a lot of changes with there new Drives, they have more choices for commutation now also, between the servo drives and control
    Modbus RS485 and CAN Communication puts them at a different level
    Mactec54
    May 2013
    32
    I would say that it probably mostly worked. Maybe I could have power cycle the servo and it might have finished. It would be interesting to see what gains it would choose. As it is I re-tuned with a bit less speed gain and got rid of the resonance I was sometimes experiencing.
    I am pretty happy with the setup I have now, though I am thinking about changing to direct drive on X and Y to get rid of the belt backlash.
    I am using the drives as position servos in quadrature step/dir mode and closing the loop around the drives with a dynomotion kflop which allows me to log following error. I did a test cut on plastic, not very dense with an 8mm end mill and interpolated a circle at 200 imp and the drives where never more than 13 steps out which is about ~.0007 on my system.
  1. Replies: 13
    Last Post: 09-24-2018, 05:17 PM
  2. DYN4 ONPOS or ALM?
    By ger21 in forum Dmm Technology
    Last Post: 08-14-2017, 04:29 AM
  3. Replies: 2
    Last Post: 06-10-2017, 03:25 PM
  4. Mach 3 WITH ESS C62 BOB AND DYN4
    By dynoluc in forum CNC4PC
    Last Post: 11-15-2016, 01:21 AM
  5. control techniques unidrive, autotune problem
    By krister_n in forum Servo Motors / Drives
    Last Post: 07-17-2011, 09:12 AM
