586,119 active members*
3,595 visitors online*
Page 1 of 2 12
Results 1 to 20 of 25
    Oct 2006
    40
    Question Turning a sphere
    Is it possible to turn a 'perfect' sphere? If so how?
    Aug 2006
    246
    How perfect? We have some diamond turning machines(Precitech) that will turn a perfect sphere within 1/4 fringe which is about 8 millionths of an inch. It's not easy though....
    :cheers:
    I don't know much about anything but I know a little about everything....
    Oct 2006
    40
    i'm just thinking hypothetical situations and i just want to know if it's possible and how they do it. i'm 20 and in cnc machining classes at school and it's just something that i was like 'is this even possible? cause i don't have any idea how to hold it'.
    Jul 2005
    12177
    Hadn't seen this one before I answered your other.
    If within better 0.001" is considered perfect then it is not too difficult on a CNC machine. I have one sitting on my desk; sphere that is not CNC machine .
    The trick is holding it to do a complete sphere. A partial sphere with a neck on it is dead simple but then you have to make a fixture to hold that partial sphere running as true as possible so you can machine off the neck and finish the whole sphere.
    If you want pictures I can do them tomorrow.
    Oct 2006
    40
    pics would be appreciated.
    pepo Guest
    I dont know why you couldnt cut it with a neck on it,then part it off. Then bore jaws to the diameter of the sphere and machine off the neck from the first operation. The neck wouldnt even have to run exactly true for the second operation only the sphere would.
    Jul 2005
    12177
    Quote Originally Posted by pepo View Post
    Well yes, that is what you do, more or less.
    Parting off is not advisable because when your spinning sphere drops down and bounces around inside the machine the surface gets damaged.
    Just having the jaws bored cylindrical is also not advisable because they only contact the sphere on a very small line and can easily damage the finish when the sphere is gripped firmly enough to machine off the neck.
    Mar 2004
    439
    bookwurm99-
    You can always machine a rough sphere and then lap it to near perfection with some relatively crude aparatus. To see what I mean, check out the Yahoo group "Spheres" http://groups.yahoo.com/group/spheres/
    I have wanted to make a floating granite ball (about 18" in diamater, floats on water pressure as a garden ornament) for a long time, and I had come across this group. I have been interested ever since I saw the 5' diamater granite ball floating on a socket pressurised with water in Epcot - and kids were spinning it one way or another.
    It's funny that cdlenterprises mentions Precitech, as when I worked there we used a similar technique to lap 1/2" test balls to ±1 millionth of an inch, and we had them sent to NIST for calibration. Also, I have a long history working with air and hydrostatic bearings, and I have always found near frictionless motion addictive.
    NEATman
    Jul 2005
    12177
    Here are the pics.
    The partial sphere is first turned with a thick neck then the neck is thinned down before cutting it off. If the neck is made too small the ball bobbles around during the turning and chatters.
    The holder for the finishing is held in the chuck and the inside liner skimmed true before use. This makes sure the partial sphere is held true.
    Just enough protrudes to turn off the neck and finish the sphere.
    This might seem a lot of effort just for a big aluminum ball. It is but it has a purpose. I am establishing the procedures for making aluminum spheres from around 2.4" diameter up to 3.4" both solid and hollow with varying wall thickness. I am working with a guy to start manufacturing really big ball Trackballs for computer access by people who have a physical disability so they cannot operate a regular mouse or trackball. We want to experiment with different size balls with different weights. Some potential users will have Cerebral Palsy so they cannot control fine motor function; for them a heavy ball that does not spin readily may be preferable. Other users may have Muscular Dystrophy or another muscle weakening disorder and they may find it better to have a very lightweight and easy to move hollow ball.
    And maybe the whole venture will fall flat on its face and I will be left with a whole bunch of aluminum marbles to play with .
    Mar 2004
    439
    Geof-
    That is one clever fixture!
    Also, that sounds like a great application. I hope your business venture works out well.
    NEATman
    Oct 2006
    40
    Quote Originally Posted by NEATman View Post
    i lived in singapore for four years and they had one about 36" in diameter at a public park. it was always surrounded by kids and even adults playing with it. i absolutely loved it and i have been looking for 10 years if there is one in houston and i haven't found one yet. i would also love to make one myself someday but i don't even have a machining job yet, much less my own machine to even think of doing it yet. probably do it when i get my own machine or when i retire in 30 years or so. i might buy one before then but it would be more fun to make one myself though. if you ever make it post pics so other people might get inspired.
    btw thanks for all the posts everyone.
    Wow Geof, that is really fantastic. Is there a name for the holder you use for finishing the sphere and is it in widespread machining use or did you design it yourself?
    Also you mention trueing it up, does that mean its disposible and you dump it after making one sphere?
    Thats a great project your working on by the way.
    Jul 2005
    12177
    Quote Originally Posted by thkoutsidthebox View Post
    I designed and made the holder on the machine it is used on.
    The trueing up is done on a replaceable aluminum insert in the holder and trueing up is only needed at the start of a batch of spheres so you do whatever is the batch size each trueing up.
    Each insert should be good for many 'trueing ups' because it is only necessary to take off a few thousandths of an inch.
    Jan 2007
    355
    Geof,
    The sphere making device is inspired.
    Your skills and experience are a godsend to those who will benefit from these trackball devices. Best of luck !
    I also wanted to mention Ripley's Museum in Myrtle Beach, SC.
    Outside the museum there is a 2000 pound granite sphere, floating on a water-filled pedestal.
    Takes very little force to set it spinning. It is truly amazing.
    What is about spheres that causes such wonderment?
    Imagine. A Yahoo group devoted to spheres. I may join...
    Jul 2005
    12177
    Quote Originally Posted by Eurisko View Post
    ....I also wanted to mention Ripley's Museum in Myrtle Beach, SC.
    Somebody must have gone around the world selling these granite spheres on water pedestals. Several locations have been mentioned here and I have seen them in Japan, Denmark and New Zealand.
    Question
    Quote Originally Posted by Geof View Post
    So heres another question that I think may have as interesting an answer as the turning of the sphere itself...how do you true up the spherical aluminium insert?
    Jan 2004
    3154
    Boring bar and a G2/G3 line in a short program, would be my method.
    www.integratedmechanical.ca
    Jul 2005
    12177
    Just like Darebee says, use a boring bar.
    Turning or boring partial spheres is fairly easy. The difficult part with boring a full hemisphere is going past zero, or even getting to zero, on the X axis. The boring bar needs clearance and of course the sphere gets in the way.
    Regarding my holder the slight truing up cut needed before use served two purposes; one was to get a true running hemisphere, the other was to establish the Z offset with respect to the center of the sphere. Both the truing program and the sphere finishing program used the center of the sphere as Z zero; once a cut had been taken it was certain that Z zero was at the center.
    Jun 2007
    32
    Floating granite ball
    Some people have mentioned those floating granite ball fountains. Only a few companys in the world can make those really big ones (2-3 meters diameter) with the accuracy that is needed to make them work. Does anyone know what CNC-machines can handle something that big and with an accuracy of a few hundreths of a millimeter.
    Jul 2005
    12177
    Quote Originally Posted by Tailgunner View Post
    Things like that are done on sphere generating machines that create a sphere by pgrinding and polishing it between two cups that carry the sphere but are not coaxial.
    Google 'ball making machines' or 'sphere making machines'
Page 1 of 2 12
  1. Object on a sphere
    By moosbach in forum Rhino 3D
    Last Post: 04-07-2011, 01:49 PM
  2. Text on a Sphere
    By wtbaker69 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-21-2010, 03:37 AM
  3. Grinding a Sphere
    By bookwurm99 in forum MetalWork Discussion
    Last Post: 04-04-2007, 12:56 AM
  4. Turning a 'dome' or half sphere..
    By hotponyshoes in forum MetalWork Discussion
    Last Post: 04-01-2007, 03:39 PM
