586,061 active members*
4,637 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Help!! What kit is best for me
Results 1 to 10 of 10
    Mar 2009
    14
    Hi everyone,
    I see a lot of people are requesting the same help as I am. I have built a machine and I am not sure what motor setup to go with. I know I need NEMA 23's but I am not sure what to buy exactly. I am running Mach3 so I know it has to be parallel port. Below is my machine and the three options I am looking at. Keep in mind, money is definitely a concern.
    my machine
Name:	my machine.jpg
    Here are the options I am looking at
    https://www.amazon.com/HOUSE-Stepper...70_&dpSrc=srch
    https://www.amazon.com/gp/product/B0...OG8I9YXT&psc=1
    http://www.cncrouterparts.com/3-driv...-kit-p-74.html
    Mar 2007
    2083
    Re: Help!! What kit is best for me
    the motors in the first 2 kits have a high inductance (9mH)
    run of a 36V power supply your machine is going to be very slow
    the router parts kit says the motors are low inductance
    but does not specify what the motors inductance is !!!
    when run from a 48V supply ,
    a motor of 3mH or less is what I would be looking for
    john
    May 2005
    1397
    Everything john said is 100% correct. However, since you said nothing about speed, and DID say you needed to save money, why not scavenge or salvage motors? There is a list of motors and where you can find them at:
    techref.massmind.org/techref/io/stepper/linistep/motors.htm
    I typically advise against trusting anything that is direct shipped from China. It's better if a US vendor is standing behind the product.
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
    Quote Originally Posted by john-100 View Post
    3mH
    http://www.cncrouterparts.com/cdata/...spec_sheet.pdf
    Mar 2007
    2083
    Ger21
    I can not open your link for some reason
    but the 3mH motors makes the router part kit a good choice
    john
    It works for me.
    You can also find it here.
    420 oz-in 3.0 mH NEMA 23 Stepper Motor, 3/8" Shaft | CNCRouterParts
    Mar 2007
    2083
    Hi Gerry
    I have it now via your latest posted link :-
    John
    Mar 2009
    14
    Hi John. So you are saying I should just save more and get the kit from CNC Router Parts? That was kind f what I thought, but I also thought there might be a cheaper place to get the same or equivalent. The price they want seems a bit high. No?
    James Newton: I am not SO hard up for money that I need to scavenge motors. I would rather buy it in a ready to go kit though.
    Mar 2007
    2083
    out of the three kits your looking at the router parts kit wins on two important factors
    the stepper motors have 1/3 of the inductance compared with the other kits (3mH v 9mH)
    and the power supply voltage is higher (48V v 36V )
    both factors will enable the router parts kit to step the motors faster
    the faster you want the motors to turn the shorter time you have for the current to reach the required current
    the higher the inductance the longer it takes for the current to build up to the set current by the drivers DIP switches
    higher voltage will also shorten the time it takes for the current to build up
    that's why the stepper drivers power supply voltage is several times the rated voltage for the motor !!!!
    the chopping action of the stepper driver and the motors inductance controls the motor current
    ( its not just the supply voltage divided by the motor coil resistance !! )
    I guess its the Leadshine MX3660 3-Axis Digital Stepper Motor Driver that adds a lot to the cost of the router parts kit
    but like the Gecko G540 saves on the interconnecting wiring between the breakout board and the stepper drivers
    if you can find a kit like the amazon kits but with stepper motors with 3mh inductance
    it could give you less expensive start
    with the option of upgrading to a 48v power supply if you need a little more speed
    John
    Mar 2009
    14
    Thanks John. I think I will just save a bit more and get the one from CNC router parts. It's pretty much a plug and go system and obviously decent quality. Thanks for you r help, I appreciate it.
