586,909 active members*
3,340 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Newbie CAM question.
Results 1 to 5 of 5
    Feb 2018
    Hi new to Fusion360 and I am attempting my first project with CAM and Fusion360. My project is some base drawer cabinets. Currently, a single cabinet with drawers takes up more than one sheet of 4x8 plywood. This is where I get stuck and I have searched all over for a tutorial that covers this. I want to go from start to finish with Fusion and currently, I don't know how to continue my nesting to the second and third sheets of plywood. I would assume that a pause is in order so the sheets can be swapped out. Can anyone point me to a tutorial that will answer this question? Thanks in advance.
    Dan
    Nov 2014
    724
    Re: Newbie CAM question.
    Welcome to the forum, Dan! Can't you just enter a manual tool change at the point the first sheet is completed? I haven't had to do this but it seems like this would be easy to do.
    David
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
    35538
    I don't know how you are doing this in Fusion, but typically, you would want each sheet to be a separate g-code program.
    Feb 2014
    187
    Thats what i do, i cant figure out how you can nest from one sheet to another??
    Aug 2009
    294
    I would model up each sheet of plywood as a separate 4X8 sheet (or whatever size you are using). Do all of your nesting in the model environment. In CAM, each sheet of plywood would be a different setup, but use the same work offsets. That way you don't have to re-zero...just load a new sheet, and then load the next program you have for the next sheet and hit cycle start.
Name:	nested parts.jpg
  1. Yet another newbie CAD question
    By binite in forum Uncategorised CAD Discussion
    Last Post: 06-27-2013, 03:13 PM
  2. Another Newbie question
    By Rickyg in forum Machines running Mach Software
    Last Post: 11-15-2012, 01:16 AM
  3. CNC Newbie question G53.5
    By LegoLogic in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-15-2012, 12:36 AM
  4. Another Newbie Question.
    By reeser in forum Mach Software (ArtSoft software)
    Last Post: 03-09-2012, 12:46 AM
  5. Another Newbie question
    By patrick kilby in forum CNC Machining Centers
    Last Post: 07-29-2009, 08:23 PM
