603,373 active members*
3,855 visitors online*
IndustryArena Forum > CNC Electronics > Dmm Technology > DYN4 1.8KW Servo Motor
Results 1 to 12 of 12
    Jul 2017
    16
    Has anyone out there done a DYN4 1.8KW spindle motor swap/upgrade on a bench top milling machine? I'm toying with the idea of going this route vs getting a VFD/upgrading the current AC motor. I've email DMM about this and they said it is quite popular. I would like feedback and any challenges that they have faced.
    Nov 2005
    222
    Re: DYN4 1.8KW Servo Motor
    I am looking for the exact same info. I am considering the 1.3kw or 1.8kw.
    John
    Jul 2010
    43
    Nov 2005
    222
    Vinnito1, Did you ever proceed with the DYN4 1.8KW on the spindle? If so, how did it turn out? Now that I have my machine working pretty well I am back to looking at the spindle conversion.
    John
    Jul 2010
    43
    What do you need to know?
    I use the 1.8kw dyn4 and am very satisfied.
    I have it set up to use as speed servo and positioning.
    Nov 2005
    222
    Lt.Dan, That is mainly what I am looking for right now is just to know someone else has done it and likes the way it works. I'm working out the details now of how I get a quadrature signal from the spindle back to LinuxCNC so I can do ridged tapping. I am going to be using a 1.8:1 tooth belt pulley ratio so I can get to 5400 rpm on the spindle. Did you run 1:1 or something else?
    John
    Jul 2010
    43
    Quote Originally Posted by rcheli View Post
    John
    I run a 2:1 pulley for 6k rpm
    I use mach3 and Ethernet smoothstepper so I can't help you with your software. But there should not be a need for feedback to your software for rigid tapping just set your z feedrate for spindle speed to the tap you are using. Its a good servo so it won't loose position.
    Nov 2005
    222
    Lt.Dan, What voltage are you running yours at? 110 would be convenient but I can do 220 if I need to. I ordered mine tonight.
    John
    Jul 2010
    43
    John
    120v will only run 1500rpm
    I run everything at 240v
    Nov 2005
    222
    I'm getting closing to install this servo on my spindle. I got the mounting hardware and pulleys ready and not it is time to gather the parts for the power and control.
    I am using LinuxCNC and a Mesa 6i25/7i76 combo that supplies 0~10 volt via a potentiometer replacement type device to control the spindle but the DYN4 drive is looking for a +/- 10 volt analog signal. It looks like I could use a Mesa 7i33. Does that seem like the best option?
    From the Mesa site:
    7I33/7I33TA Quad Analog servo interface
    The 7I33, 7I33T and 7I33TA are a 4 axis analog servo interfaces intended for operation with MESAs Anything I/O cards in motion control applications. The 7I33 takes the PWM and direction signals from the Anythng I/O card and converts them to +- 10V analog output voltages for direct connection to analog input servo amplifiers. The 7I33 also conditions the encoder input signals with input filters for TTL inputs or RS-422 recievers for differential encoder inputs. The controller connection is a 50 pin header that matches the pinout of the Mesas Anything I/O cards. Another 50 pin header is used for servo amp/encoder connections. The -TA version uses 3.5 mm pluggable screw terminal plugs (included). (7I33TA shown)
    John
    Nov 2005
    222
    I just heard back from Mesa. That said the 7i83 would be the easiest so I ordered one of those. They also said that it could be done with the 0-10v 7i76 interface and a relay.
    Feb 2019
    15
    free shipping
  1. new dyn4 autotune
    By boss4 in forum Dmm Technology
    Last Post: 02-05-2018, 04:35 AM
  2. Replies: 1
    Last Post: 12-13-2017, 10:07 PM
  3. DMM Dyn4 & 1KW AC Servo motor reliability & quality
    By Marty_Escarcega in forum Dmm Technology
    Last Post: 06-27-2017, 03:01 PM
  4. dyn4 servo creeping or twitching along by itself
    By chrsbrbnk in forum Dmm Technology
    Last Post: 10-19-2016, 05:08 AM
  5. Axis servo motor vs. Spindle servo motor
    By iyerks in forum Servo Motors / Drives
    Last Post: 09-25-2012, 04:58 PM
