586,108 active members*
3,250 visitors online*
IndustryArena Forum > Community Club House > International / Regional Forums > USA Club House > need help, cut guru bits for routing wood on a kongberg xn
    Feb 2018
    30
    im running a kongsberg xn, using bits from cut guru, and i have a job which requires cutting 4 in coasters from a sheet of birchwood. the feed rate and chip load that they supply dont seem accurate when it comes to cutting wood and im hoping someone here has more experience (i only have 2 years experience routing) either on a kongsberg or with cut guru bits that can give some advice. the wood is 5.6 mm thick and im going to be using either the w2-625d or the w2-418d. so far im cutting in two layers and running around 40,000 rpm with a chip load ranging from 200 - 400. any advice on chip loads, feed rates and rpm would be greatly appreciated.
    Re: need help, cut guru bits for routing wood on a kongberg xn
    15,000 rpm and 125ipm
    Feb 2018
    30
    with those settings, would you cut in one pass or multiple passes?
  1. Replies: 0
    Last Post: 08-31-2014, 06:38 PM
  2. Replies: 0
    Last Post: 08-31-2014, 02:19 AM
  3. PCB routing bits
    By 071203 in forum CNC Tooling
    Last Post: 08-23-2012, 05:17 PM
  4. Quick change bits on wood routing machines?
    By DennisToledo in forum CNC Tooling
    Last Post: 09-15-2011, 09:19 PM
  5. Routing bits to cut thru MDF
    By razza62 in forum Commercial CNC Wood Routers
    Last Post: 02-09-2008, 12:24 AM
