586,075 active members*
4,127 visitors online*
Results 1 to 6 of 6
    Aug 2007
    224
    rotary hydraulic piston Assembly
    Hello experts this is FSA from Karachi Pakistan...I need help to assemble this piston sphere to in its cavity...I have machine both parts but can't find any way to assemble it that can work as this made for please check attach jpeg for understanding.
    Regards
    Fisa
    Aug 2007
    224
    Regards
    Regards
    Fisa[/QUOTE]
    Aug 2007
    224
    rotary piston Assembly
    Regards
    Sep 2006
    6463
    Re: rotary piston Assembly
    Hi, for a housing design like that which has a captive ball in it you have too much housing around the ball to allow assembly.
    Normally the ball is sprung into the housing by pressing.....both parts are made from high tensile steel and are hardened and tempered.
    You could make the housing with a straight bore and a rounded bottom at the end then spin or swage the housing around the ball...........you can get quite a close fit with spinning.
    Ian.
    Sep 2006
    6463
    Re: rotary hydraulic piston Assembly
    Hi you have posted this twice.......
    Aug 2007
    224
    Thanks bro for you advice... it can be happen ...but wat process use the original manufacturer for production ...can you point me any link of video of these components assembly.
    Fsa
  1. Hurco BMC4020 CTS Hydraulic rotary joint leaking.
    By Shishkinnick in forum HURCO
    Last Post: 11-09-2016, 12:10 AM
  2. Replies: 0
    Last Post: 10-21-2014, 02:49 AM
  3. Rotary Pneumatic Piston
    By Syphonics in forum Mechanical Calculations/Engineering Design
    Last Post: 04-29-2009, 07:36 AM
  4. Link to Piston/rotary engine under development
    By mongo in forum I.C. Engines
    Last Post: 07-17-2005, 08:42 PM
  5. Replies: 1
    Last Post: 12-29-2003, 02:06 AM
