586,103 active members*
3,651 visitors online*
IndustryArena Forum > CNC Electronics > Leadshine > Four motors on a Leadshine MX3660
    Jan 2016
    I am assembling a 3 axis woodworking CNC router. The Y axis will have two right twist acme leadscrews, each with its own stepper motor turning in the same direction. Can I connect the two Y axis motors to the Y axis driver on an MX3660? I know they make the 4 axis MX4660, but I can get a good deal on the MX3660. Gryphon CNC is doing the same thing, but with one motor turning opposite the other.
    Feb 2007
    4553
    Exclamation Re: Four motors on a Leadshine MX3660
    Trideciple,
    The short answer is no, it is not recommended and there is a good chance doing so would smoke the offending drive axis power transistors in the process.
    Have a most awesome evening,
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  1. Leadshine mx3660 and fuling vfd 2.2kq with Mach 3
    By Daman691003 in forum Leadshine
    Last Post: 10-16-2017, 05:29 PM
  2. Leadshine MX3660 3-Axis Stepper Drives
    By Vermeersch2080 in forum Leadshine
    Last Post: 04-01-2017, 04:16 AM
  3. Replies: 0
    Last Post: 03-05-2017, 08:47 PM
  4. Replies: 4
    Last Post: 07-10-2015, 06:15 AM
  5. Leadshine MX3660 and index pulse card
    By Blakea1790 in forum Benchtop Machines
    Last Post: 01-07-2014, 07:13 PM
