603,893 active members*
4,089 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Polls > What is the best linear guide for plasma cutting machine (3000x1500 mm)
View Poll Results: What is the best linear guide for plasma cutting machine (3000x1500mm)
Voters
17. You may not vote on this poll
  • linear ball bearing
    8 47.06%
  • miniature profile rail guide
    4 23.53%
  • V linear guide systems
    5 29.41%
  • other
    0 0%
    Mar 2018
    Hello,
    I am trying to build new CNC plasma cutting machine (3000x1500 mm ) with average performance, I want to know how to choose the best linear guide (Y and X Axis) for my application in term of cost/service life /
    May 2015
    686
    Re: What is the best linear guide for plasma cutting machine (3000x1500 mm)
    MIne's roughly 1200 x 1300.
    For the X, I used 2 x HGR15 linear rails, 3:1 rack and pinion drive, NEMA 23
    For the Y, I used 1 x HGR25 linear rail each side of the table, 5:1 helical rack and pinion drive, NEMA34
    If I did it again, I'd just use 1 x HGR25 on the X as well
    Rod Webster
    www.vehiclemods.net.au
    Dec 2013
    The Best to use is PMI, they have worked the best for me i use the SL kit with double seals and metal scrapers the blocks are fully sealed and work well in dirty environments I also use oil instead of grease helps prevent plasma BB's from building up around the blocks, If you use them in an exposed to weather situation keep them sprayed with phosphate type lube like royal purple Max film. as for gear boxes i keep them all the same if something goes wrong (and it will) it make diagnostics easier and you can swap motors around for testing
  1. Replies: 0
    Last Post: 07-14-2015, 06:30 AM
  2. Higher Precision 4 Axis CNC Machine with Double Linear Guide
    By Winni-Sinomac06 in forum Commercial CNC Wood Routers
    Last Post: 06-26-2015, 06:38 AM
  3. Guide for Choosing Plasma Cutting Machine Manufacturers
    By Bill Levis in forum South Africa Club House
    Last Post: 11-25-2014, 08:42 AM
  4. How to machine ends of linear guide rails.
    By SES1 in forum Linear and Rotary Motion
    Last Post: 02-12-2008, 09:27 PM
