603,365 active members*
3,262 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Controller Cards > Can you convert a 3 axis AKZ250 to 4 axis?
Results 1 to 6 of 6
    Mar 2014
    1141
    I have a 3 axis AKZ250 USB board (aka Leafboy card). On the right side of the board (see the yellow circle on the attached image) there is two optos missing. Looks like soldering there the right components will make it 4 axis however that's just my guessing. Has anyone tried this? Did/will it work?
    Thanks in advance.
    Best,
    Suat
    Nov 2012
    1283
    Re: Can you convert a 3 axis AKZ250 to 4 axis?
    It should work if the firmware is the same for 3-axis and 4-axis cards. But I suspect the 4th axis is disabled in the firmware.
    Mar 2014
    1141
    I guess you are right.
    Oct 2005
    Ive just soldered 2 new chips.. damn no action. how to get the firmware?
    did`t you ever get it to work ?? same issue here
    Mar 2014
    1141
    If you are asking me, sorry I've never tried.
    Sent from my MI 5s Plus using Tapatalk
  1. Setup and wiring of Mach3 USB 4 axis Motion Controller AKZ250 from Leafboy77
    By MartinBarfoed in forum Stepper Motors / Drives
    Last Post: 04-02-2019, 11:50 PM
  2. Convert Spindle as Z Axis
    By kNucklBustr in forum X3/SX3/G0619/G0463
    Last Post: 12-25-2013, 06:18 AM
  3. Convert a 3-axis CNC Mill to a 3D Printer?
    By CNC-Joe in forum 3D Printer / 3D Scanner Discussion
    Last Post: 05-18-2013, 11:58 PM
  4. convert ez trak 2 axis to 3 axis
    By john_hoek in forum Bridgeport / Hardinge Mills
    Last Post: 12-09-2010, 01:02 AM
  5. how to convert spindle rotation to 4th axis ?
    By max_imum2000 in forum Mechanical Calculations/Engineering Design
    Last Post: 03-14-2007, 09:17 PM
