586,117 active members*
3,438 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > J425 Draw Bar problem
    Apr 2018
    Hello,
    I have a Draw Bar problem that doesn't allow me to remove the CAT 40 tool holder. Is there a way to manually release the tool holder? I have the axis reference at the X & Y, but the Z seems to over shoot by .0001. The air pressure is above 80psi. I seem to have nothing at the engage/release switch.
    Bob
    Oct 2017
    27
    Re: J425 Draw Bar problem
    Hi Bob, I have a J425 with a Dynapath Delta40 control. Maybe I can help. Was the drawbar working before and now it does not? Please help with a little background information. If it was working and quit with one specific tool, maybe the retention knob is a problem (out of spec) and the mechanism "locked up." Do you hear the air solenoid valve actuating, but the drawbar remains clamped, or nothing happens at all? If it sounds like things are working but the tool does not release, then some level of mechanical agitation might be in order. I recommend a rawhide, plastic or dead blow hammer. But be careful, when the tool comes out it will drop - so put a sheet of plywood or wood block under it. Also, excessive force may damage your spindle so easy with the hammer. A steel hammer will provide the best results but is also most likely to damage your spindle.
    If nothing is happening when you operate the unclamp switch, then you will need to troubleshoot the drawbar system. I'll wait for more details from you before I venture down that path. Do you have the Tree manual and electrical drawings for the machine?
    - David
    PS, I don't check this forum often. I get weekly emails if there is a topic update. But I will try to remember to check this thread.
  1. Haas vf 0 tool not clampe draw bar problem -VIDEO-
    By sedakszyn in forum Haas Mills
    Last Post: 01-25-2017, 07:11 PM
  2. Problem With Newly Draw Software- Please Help !!!
    By hubery in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-07-2013, 04:29 PM
  3. Sheetcam from Corel Draw Problem
    By VERSIUS in forum SheetCam
    Last Post: 09-18-2012, 05:47 PM
  4. draw bar problem
    By supreme in forum Cincinnati CNC
    Last Post: 01-29-2010, 07:56 PM
  5. Corel Draw Problem...
    By chuck_bizzle in forum Uncategorised CAD Discussion
    Last Post: 10-04-2007, 05:46 AM
