586,112 active members*
3,068 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Stepcraft > Adapting a plasma cutter to the stepcraft
    Apr 2018
    Has anyone attempted to create a toolholder and adapt a smaller plasma cutter to the stepcraft system? I currently have a need to cut 1mm thick copper parts and was thinking of building a system to adapt the spindle holder to, is this possible to do? Could anyone recommend an inexpensive cutter (wont be running for more than 20 minutes a day) or any suggestions of how to do this or if its possible/not possible?
    May 2006
    20
    Re: Adapting a plasma cutter to the stepcraft
    Since plasma cutters typically run about 20,000 deg F, I would personally forget this idea and just cut copper with a standard end mill. 1mm thick copper is easy to cut.
  1. AngelBlade plasma cutter torch and plasma cutter consumables
    By Aaron Bruce in forum News Announcements
    Last Post: 09-16-2015, 08:52 AM
  2. Replies: 0
    Last Post: 09-09-2014, 10:09 AM
  3. adapting a plotter cutter to cut cylinders
    By Thessinger in forum Waterjet General Topics
    Last Post: 01-13-2011, 05:20 PM
  4. Adapting a new interlogic(THC) to an ats300/galil plasma?
    By kirkchabot in forum CamSoft Products
    Last Post: 12-29-2008, 03:34 PM
