586,469 active members*
3,133 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > (5 axis breakout board) Want to add a relay module and a charge pump . . .
    Aug 2012
    18
    I have been searching and trying different things for the last month and I would really like some help! Here are the two main questions I have.
    1) How can I add an additional relay module? Adding a marker/scribe so need another relay
    2) I'm using the fixed relay on the board right now to trigger a plasma torch. How can I can disable the relay on the board from tuning on, It clicks on for roughly a second when power is applied on boot up though the usb/parallel port. Charge pump? If so how would I wire one up to this board?
    I'm running mach 3, I'm using a generic 5 axis breakout board (See pictures below) with a cncdrive uc100, I have a dual relay module ready to wire up just need some help with wiring and setting up ports and pins.
    Thanks!
    Attached Thumbnails Attached Thumbnails 5-axis-cnc-interface-adapter-breakout-board-free-usb-cable-littlecraft-1603-12-littlecraft@5.jpg   s-l1600hhh.jpg
    Aug 2012
    18
    Quote Originally Posted by LSX View Post
    Thanks!
    Bump anyone
  1. Syil X5 Speedmaster - Relay on breakout board failure
    By Bob La Londe in forum Syil Products
    Last Post: 04-24-2017, 06:32 PM
  2. 5 axis breakout board and 3 single axis drivers tb6560, not working
    By MROX15 in forum Stepper Motors / Drives
    Last Post: 11-06-2013, 07:34 PM
  3. 5-axis CNC Breakout board and problem with connection display module
    By lasek in forum CNC Machine Related Electronics
    Last Post: 05-23-2013, 09:52 PM
  4. need help connecting breakout board to relay to vfd
    By daniellyall in forum Phase Converters
    Last Post: 04-20-2012, 04:33 AM
  5. Proper use of Charge Pump on CNC4PC breakout board?
    By Scott Kelley in forum Controller & Computer Solutions
    Last Post: 06-18-2009, 10:40 PM
