603,969 active members*
1,505 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > Syil X4 Pneumatic Drawbar
Results 1 to 7 of 7
Hybrid View
dpaish Syil X4 Pneumatic Drawbar 04-21-2018, 06:50 AM
Clockworld Re: Syil X4 Pneumatic Drawbar 04-22-2018, 09:05 AM
dpaish Re: Syil X4 Pneumatic Drawbar 04-22-2018, 06:28 PM
Clockworld Re: Syil X4 Pneumatic Drawbar 04-23-2018, 04:51 PM
dpaish Re: Syil X4 Pneumatic Drawbar 04-24-2018, 04:12 AM
Dave2024 Re: Syil X4 Pneumatic Drawbar 11-10-2024, 01:36 AM
Clockworld Dave, I'm away until... 11-14-2024, 02:56 PM
    Oct 2003
    57
    Greetings,
    I convinced Syil Canada (Keith) to allow me to complete the Syil X4 Pneumatic Drawbar project. Keith designed and built 5 kits before he shelf the project. I got one working and 4 other kits available. What a great upgrade!
    Attachment 391640
Name:	Side Complete 2.jpg
    https://youtu.be/_nTpEeo2u3U
    Oct 2013
    23
    That is a very neat looking setup. What is the price of this?
    Would love to fit something like this to my X4+
    Matt
    Oct 2003
    57
    power draw bar kit = $550
    pan cake Cylinder (you order, I have part number) = $175 (full retail)
    1/2 Aluminum scrap = CHEAP
    3/8 ready rod = $10.00
    2 way 5 port switch (you order, I have sample part number) = $25.00
    Air lines and fittings (you supply)
    1/4 / 20 bolts (you supply)
    set screws (you supply)
    one spring pin
    I have all pictures of the process. You have to fabricate the install brackets yourself, as I did not make any drawings. Very simple fabrication, took me couple evenings to complete.
    If you get the pan cake cylinder off ebay and switch you can build this cheaper than full retail around 700 cnd all in.
    Oct 2013
    23
    Hi
    Thanks for the update. So I am clear, what is in the drawbar kit?
    Matt
    Oct 2003
    57
    Greetings, See picture that indicates IN KIT. You get that machined part and the machined insert with the 5 belleville washers. You have to build the brackets, purchase the cylinder, rod and button.
    Attachment 391822
    Attachment 391824
    Attachment 391826
    Apr 2024
    24
    Hello, I know this is an old forum post I'm commenting on but id like to do something similar to to my Syil X4 and change out the draw bar and instead use a hand lever to compress the springs. Does anyone recommend where to get the longer draw bar? Would it just be a matter of using a stick of threaded rod and some belleville spring washers with a nut welded at the top? Also how many belleville washers would be needed to keep it as tight as possible? Thanks
    Oct 2013
    23
    Quote Originally Posted by Dave2024 View Post
    Dave, I'm away until December, but give me a nudge then and I'll refer to my notes. My drawbar was loosely based on the Tormach design and still needs implementing! However, my X4+ is undergoing z axis bearing replacements and new electronics for UCCNC / AXBB-E
    Matt
  1. Gauging interest: pneumatic drawbar kit for G0704
    By inthebay in forum Benchtop Machines
    Last Post: 01-03-2017, 05:44 AM
  2. Pneumatic Drawbar Plans
    By Starleper1 in forum News Announcements
    Last Post: 11-27-2011, 09:14 PM
  3. Replies: 39
    Last Post: 08-07-2010, 04:59 AM
  4. Pneumatic drawbar, spindle bearings...
    By altaic in forum Mechanical Calculations/Engineering Design
    Last Post: 07-05-2009, 12:34 AM
