586,047 active members*
3,734 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Stepper driver board replacement
    Jan 2011
    14
    Hi
    A bit not familiar with that type of replacement.
    I have 4 nema motors Keling KL23H276-28-4B and I work with Mach3 software.
    My Rockcliff stepper driver card 4X discontinued (PN RCF_00110) needs to be replaced. (see picture attached)
    What type of stepper driver card would you suggest me as a replacement, with a good quality-ratio and using the same Mach3 settings already registred on my pc.
    Jack
    Jan 2007
    36
    Re: Stepper driver board replacement
    Get a Gecko G540. Have been using there drives for years.
    May 2005
    1397
    Gecko might be a bit of overkill, but if you have the money, go for it.
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
    Jan 2011
    14
    Thank you for your reply,
    If you have suggestions for cheaper versions it would be appreciated.
    Jack
    May 2005
    1397
    Quote Originally Posted by JackMath View Post
    Jack
    *cough*
    http://techref.massmind.org/techref/io/motors.htm
    Still overkill for a replacement for that board, but they cost a lot less because they are kits.
    Are you not happy with rockcliff? They do make a replacement, with a better chip:
    https://www.rockcliffmachine.com/product/drv8825-step-motor-driver/
    Very very cheap. If the original worked, the new one can probably manage. But neither of those drivers can get the full performance out of your 3 amp motors. You need a driver than can do 3 amps all day long, so I would really recommend a 4 amp driver.
  1. Driver board and stepper motors?
    By cvetan in forum Stepper Motors / Drives
    Last Post: 02-18-2016, 01:07 AM
  2. Replies: 4
    Last Post: 01-23-2015, 07:46 PM
  3. Help picking replacement stepper driver board
    By herring_fish in forum Hobby Discussion
    Last Post: 02-15-2012, 04:55 AM
  4. Stepper driver board
    By 4lowie in forum Australia, New Zealand Club House
    Last Post: 09-09-2011, 09:31 AM
  5. 6 leads stepper motor connect to TB6560AHQ stepper driver board
    By wf1318 in forum Stepper Motors / Drives
    Last Post: 07-25-2010, 08:19 AM
