586,121 active members*
3,761 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > NPT to NPS threading help HAAS ST20Y!
    Hello All,
    I've got a 316 stainless part calling for a 3/4" NPT to NPS thread. I have attached a clip of the drawing. I am completely stumped! I Don't believe that I can run a tapered G92/G76 in conjunction with a straight code of the same value. In my opinion the threads will not match up due to the longer distance on the taper. Any help/input would be helpful.
    Jun 2015
    119
    Re: NPT to NPS threading help HAAS ST20Y!
    I think what you want is a G32 cycle. It can do changing angles like that (taper to straight, etc).
    From the Haas online manual: "G32 differs from other thread cutting cycles in that taper and/or lead can vary continuouslythroughout the entire thread. In addition, no automatic position return is performed at theend of the threading operation."
    Hope that helps.
    ____________________________
    My blog: http://www.fletch1.com
    Thank you so very much. I have pulled up G32 on the HAAS DIY page and am studying it right now.
  1. Haas ST20Y bar feeder questions
    By slazenger7 in forum Haas Lathes
    Last Post: 12-21-2017, 05:03 PM
  2. Bad finish ST20Y
    By Greenworks in forum Haas Lathes
    Last Post: 11-24-2016, 06:10 PM
  3. Haas ST20Y NX Post Processor
    By PEAK in forum UG NX
    Last Post: 08-22-2012, 04:51 AM
  4. haas threading macro
    By xj0696 in forum Parametric Programing
    Last Post: 04-08-2011, 09:20 AM
  5. Lefthand threading on a Haas Tl2
    By Peter Gibbs in forum Haas Mills
    Last Post: 07-29-2006, 02:25 AM
