586,553 active members*
3,455 visitors online*
    May 2018
    Copying programs on Fanuc 10T
    I have every manual that Fanuc and Mori-Seiki were willing to sell me. I still can't figure out how to clone a program on our ancient SL-15.
    Every time I try it says "NO OPTION". I just want to create a copy of a program that's already on the machine so that I can mess with it without wrecking the original.
    2932
    Re: Copying programs on Fanuc 10T
    I would *guess* you don't have an option installed such as Extended Edit. Can you punch the programs out and edit them on a PC?
    Nov 2008
    94
    If you are trying to pull a program out of the Mori's control onto a PC:
    AND If you do not have a RS-232 Port.
    Then you need a BTR board (Behind the Tape Reader) to be installed.
    This will allow you to interface a PC with the control.
    It tricks the control into thinking it is receiving punched tape.
    Basically a binary to punch tape translator.
    On my setup: I can't pull a program. Only send. So my edits only should be done on the PC. Then sent back to the CNC.
    Some BTR's will send & receive.
    You will also need some kind of communication software and a cable wired correctly between the PC & CNC.
    There are companies that offer a full package. Google Behind the Tape Reader.
    JT
