588,656 active members*
6,028 visitors online*
    Sep 2005
    67
    reading modbus inputs
    Hey all,
    i KNOW that I know how to do this, but for some reason, every time i try to sit & write my code, i am getting a massive block...
    Basically, i'm writing an m-code for use as a "is an input active" to verify that it's "OK" to move my machine into place... running it through a modbus I/O setup.
    I know that i could just map the modbus pin to my Input #_ in Ports & Pins, but would prefer to stay with a direct modbus read/write... as the machine could potentially need more inputs than I am allowed within P&P...
    I just can't remember how to directly access my modbus inputs via the vb script that will be within my m-code. If someone could please shed the fog that seems to have lodged in my head over the weekend, i would really appreciate it!
    Thank you EVER so much!
    -Nate
    Sep 2005
    67
    yeah, so.. figured it out...
  1. Modbus to run GS-2 drive?
    By mecheng10 in forum Mach Mill
    Last Post: 06-17-2012, 07:01 PM
  2. Mach3 with Hitachi VFD using Modbus
    By swinn in forum Mach Software (ArtSoft software)
    Last Post: 11-28-2008, 07:44 PM
  3. EMC2/Modbus......HELP!
    By pauldkeeton in forum LinuxCNC (formerly EMC2)
    Last Post: 02-18-2007, 11:47 PM
  4. modbus device
    By Drew in forum Machines running Mach Software
    Last Post: 02-11-2007, 08:59 PM
