586,117 active members*
3,606 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Hardware > Laser Machine Stopped Working, LCD Very Dim, Need Advice.
    May 2018
    Greetings from Indonesia.
    My old Chinese CO2 laser machine suddenly unable to work properly and the LCD goes very dim (the backlight is OK but the texts are very dim).
    After selecting the files, the panel freezes and have to be restarted. Sometimes the PC connected to it cannot recognize the machine.
    Is this a power supply problem? Anyone have a solution for this?
    Thank you in advance for your help.
    Re: Laser Machine Stopped Working, LCD Very Dim, Need Advice.
    Hey there,We can’t infer directly that your machine has a power supply problem.First, it might be a problem with the cooling system of your CNC laser cutting machine. Check the professional water cooling system and ensure the water is under normal circulation.To check if it’s a power supply problem, there’s an ammeter on the machine. The ammeter measures the current supplied to the laser cutting machine. If the pointer on the ammeter deflects more to the left, then you have a power supply problem. Check the machine card with an electric meter to confirm if it isn’t a card signal problem.You didn’t specify the brand of your Chinese CO2 laser machine. If you're planning to replace then you can check out https://heatsign.com for proven laser machine solutions
  1. 60w laser just stopped working. Wondering if you folks might be able to help.
    By GoldieWilson in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-27-2017, 08:12 PM
  2. Md1-stopped working
    By Scrambled1 in forum HURCO
    Last Post: 05-11-2016, 08:32 PM
  3. advice for a good Laser Cutter - 400x600 working area -
    By tota76 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-20-2014, 02:42 AM
  4. OUtlets in back of machine stopped working
    By SwampDonkey in forum Tormach Personal CNC Mill
    Last Post: 10-25-2014, 03:50 PM
