586,071 active members*
3,900 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Can poor engraving on Aluminium be 'cleaned up'?
    Jan 2007
    626
    I have just attempted some letter engraving on the back of my new controller case and it didn't come out as nice as I'd hoped. Using the 'trial and error' method, as specific info seems hard to find.
    I used a 0.8 mm straight single flute cutter and I have some burrs on the edges.
    Also used a Fogbuster with Kero in it.
    I will use a 30° V bit next time as that gave better results on a test I did......doh. Letters are 10 mm high.
    Is it possible to clean up the burrs somehow, to try and salvage the work. Not expecting a miracle, just some improvement.
    Was thinking of a scouring pad maybe? A bit concerned about scratching the rest of the Ali. Don't want to make MORE work fixing scratches after I remove the burrs...lo
    Some sort of polishing?
    Run a small chisel gently along the burrs?
    Dunno....Hoping someone has been down this track before....
    I may consider inking the letters in black as well.
    Steve
    Attachment 393634
    Attachment 393636
    Apr 2018
    34
    Re: Can poor engraving on Aluminium be 'cleaned up'?
    do this all the time. use coarse steel wool. it will pull those burrs off and clean it up brilliantly. cheap. easy. effective. good results.
    May I also suggest using a ballnose with that type of lettering?
    I've done small engraving jobs with a 1.5mm dia ballnose 24000 rpm 500mm/min feed rate
    and a 0.25mm max depth of cut per pass.
    I usually dab a bit of mineral spirits - paint thinner - varsol. works wonders.
    go easy, don't get greedy with the depth of cut. hope this helps
    Jan 2007
    626
    Thanks Al,
    I didn't think of Steel Wool, but in this case there is a 'coating' on the aluminium that comes of with any abrasive.
    I have let it go.....WIll do better next time.
    Never thought of ball nose bits either so will try one of these next, thanks. Have to order some.
    I thought kero in a Fogbuster would be great but maybe not after seeing the results. Its all part of the fun...thanks for the tips!
    Steve
  1. Engraving letter in aluminium
    By pretorian77777 in forum ArtCam Pro
    Last Post: 02-26-2014, 02:54 PM
  2. Right tool for engraving at aluminium - CNC
    By KIBLA`s in forum Engraving Machines
    Last Post: 12-11-2010, 04:38 AM
  3. BF20 (G0705) Power Draw Bar Build (Poor, poor mans drawbar)
    By zerodegreec in forum Benchtop Machines
    Last Post: 09-14-2010, 09:01 AM
  4. Can encoders be cleaned?
    By hawkeyemfg in forum MetalWork Discussion
    Last Post: 06-29-2010, 03:13 AM
