586,076 active members*
3,726 visitors online*
IndustryArena Forum > CAM Software > EZ-CAM Solutions > EZ CAM File converted
Results 1 to 8 of 8
    Dec 2014
    4
    Hey Guys,
    Would anyone be able to convert a file over for me? I have an old file that I have from when i use to use V19. I no longer have the software and just want to know if someone can open the file for me and save it as a DXF.
    Thanks for the help!
    Dec 2012
    395
    Re: EZ CAM File converted
    Hi Vulcan,
    I'am now not at the workshop but tomorrow I can convert your file to DWG/DXF or IGES.
    At home I use sometimes the demo version of our 2016-v23 license at the shop, results shown in the attachments
    Regards,
    Heavy_Metal.
    Dec 2014
    4
    That would be awesome!!! The DWG/DXF would be perfect if you dont mind! I really appreciate the help.
    Dec 2012
    395
    Hi Vulcan,
    Did you machine the file, I see that you miss 2 pockets, image #4.
    The result of the DXF would be like image #3.
    At home I can't save the file, tomorrow I'll send you the correct one.
    Regards,Heavy_Metal.
    Dec 2014
    4
    Hey Heavy_Metal,
    Yep, I machined the file. I just engraved it as pockets on an aluminum panel. I use to make custom crab pots with these files.
    Image 3 looks like it should be good for me. I probably separated the other pockets for some reason but I dont remember why, its been a few years.
    Thanks again for the help!
    Dec 2012
    395
    Hi Vulcan,
    The Zip-file contains 2 different DWG and DXF files, the #1 are the original with dots in the pockets, EZCAM shows them as green triangles, see image #5.
    I removed them in the #2-files, I also saved the DXF as ASCII and Binary DXF-files.
    I hope it will work for you.
    Regards,
    Heavy_Metal.
    Dec 2014
    4
    Hey Heavy_Metal,
    That works perfect!! Thanks a lot for your help Heavy_Metal! I really appreciate it!
    Dec 2012
    395
    Hey Vulcan,
    You’re welcome.
    Heavy_Metal.
  1. logo converted to machine type file
    By woodman08 in forum Gorilla CNC Machines
    Last Post: 08-12-2014, 10:26 PM
  2. STL file looses surfaces when converted
    By SchulzeA in forum Mastercam
    Last Post: 01-20-2013, 07:56 AM
  3. *.jpg file converted to a vector and cut
    By woodman08 in forum LOGILASE Laser
    Last Post: 11-09-2011, 01:42 AM
  4. Need .CDR file converted to .DXF
    By seansear in forum Uncategorised CAM Discussion
    Last Post: 01-11-2008, 02:23 AM
  5. need Autocad .dwg file converted
    By RcCNC in forum Mastercam
    Last Post: 04-29-2005, 10:10 PM
