586,119 active members*
3,472 visitors online*
Results 1 to 9 of 9
    Sep 2009
    135
    Cobra 42 21T backup
    Does anyone have the procedure to do a full backup to include the ladder for the 21T controller?
    I tried doing a backup to the pcmcia card in the controller and electrical cabinet. It did not recognize that there was a card there.
    I have been able to back up what I can with the rs232 cable. I just can't seem to figure out how to get the ladder out of it.
    Sent from my SM-G955U using Tapatalk
    May 2016
    526
    Re: Cobra 42 21T backup
    What size is the PCMIA Card ?
    Sep 2009
    135
    It looks like one of these.
    Nov 2007
    361
    Quote Originally Posted by cooperjm View Post
    If I were you and you cant get it backed up take pictures of each page with your cell phone, You would have to go thru it manually and make the necessary changes by hand but at least you would have it
    Sep 2009
    135
    I have taken pictures of the various screens that will not punch out. That method will not help with the ladder though.
    Nov 2007
    361
    I must have misunderstood what you are trying to do with the ladder ? The ladder for a cnc control is to show/explain where certain components are located and or if they are being used at a certain time . What is it that you are trying to do ? reload it into the system after a memory reset?
    May 2016
    526
    Quote Originally Posted by Michael82 View Post
    If you need a pmc ladder back up you will need an sram card
    The memory card your using is a flash card
    Whereabouts are you maybe someone on here is local to you
    If your doing a memory clear the old file should be ok
    Sep 2009
    135
    So how do you get the controller to back up to the SRam card?
    May 2016
    526
    You put the SRAM card in the same place as you put the PCMIA card (on the I/O Board )
    Then power up holding the two right hand soft keys under the screen
  1. Cobra 51 question
    By joeyjrc in forum Hardinge Lathes
    Last Post: 08-07-2017, 03:44 PM
  2. looking to buy cobra 42 need info
    By mls in forum Hardinge Lathes
    Last Post: 03-29-2013, 09:43 AM
  3. Cobra penis
    By eartaker in forum Hobby Discussion
    Last Post: 02-05-2011, 12:45 AM
  4. Homing a Cobra 65?
    By H234 in forum Hardinge Lathes
    Last Post: 02-05-2009, 08:37 PM
  5. Cobra RS3-P
    By marcoheineken in forum RC Robotics and Autonomous Robots
    Last Post: 11-29-2006, 03:50 PM
