586,051 active members*
3,776 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > Dolpin Partmaster v14 cad cam 2d array or pattern
    Feb 2016
    50
    I have a project requiring manufacturing identical parts. I have the contours and points done. But how can I array/pattern them so I can have them nested on a single material and machine 50 at a time?
    Feb 2007
    413
    Re: Dolpin Partmaster v14 cad cam 2d array or pattern
    Hello,
    You need to use the miscellaneous command Repeat to create this.
    The general format is :--
    Repeat on - set XY offsets or rotations etc
    Select tool #1
    Goround Con1, left ..... etc
    Goround Con2, right .... etc
    Repeat off
    Repeat on - set XY etc
    Select tool #2
    Drill Pat1
    Repeat off
    Using this method, all the Contours would be machined and then all the holes drilled.
    If you need to machine all featues in the first location and then repeat them, use this method
    Repeat on ..... set XY etc
    Select tool #1
    Goround Con1.....
    Goround Con2 ....
    Select tool #2
    Drill Pat1 .....
    Repeat off.
    Please not that you will no see the toolpaths until you have used the repeat off command and then Run the program.
    ATB
    Andre
    Feb 2016
    50
    Oh OK I see now... TX very much! I was able to do what I was wanting in the 3d Cam with the pattern function. I will go back and redo in the 2d Cad just to learn it better. TX
  1. Array question
    By gcddarren in forum Torchmate
    Last Post: 12-29-2015, 01:37 PM
  2. Eagle PCB array?
    By stk2008 in forum PCB milling
    Last Post: 03-21-2011, 07:05 PM
  3. Pin array
    By sp1nm0nkey in forum Mastercam
    Last Post: 07-05-2009, 03:27 AM
  4. Array with v20
    By DEW in forum BobCad-Cam
    Last Post: 11-21-2007, 12:50 AM
  5. LED array sequencer
    By MrWild in forum CNC Machine Related Electronics
    Last Post: 11-21-2006, 06:31 PM
