603,316 active members*
2,062 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Surface contour toolpath (odd)
    17
    Hi Folks,
    I'm in Mastercam X trying to do a contour surface finish toolpath.
    The geometry I need to cut looks like a funnel in a block of
    metal with 4 vertical slots cut into the funnel. I've created surfaces on the inside of the funnel and over the slots too.
    When I specify a 1/4" ball endmill Mastercam has the tool rising and skipping (retracting) over a small section of the then coming back down to the inside surface and cutting almost like the toolpath is stuttering or jumping over a feature when no feature is there.
    Yet when I specify a 1/4" flat endmill the tool path is nice and smooth.....no retracting.
    I do get the message"Check and drive stock to leave are identical. Adjust check stock
    by plus or minus cut tolerance for crisper tool motion near sharp corners formed by check
    and drive geometry.
    Any ideas?
    John
    Apr 2003
    3578
    Email me your file or post it here and I will review and answer.
    Cadcam
  1. Help with surface toolpath.
    By M-man in forum Mastercam
    Last Post: 04-12-2007, 09:02 PM
  2. Surface toolpath
    By Julian M in forum Mastercam
    Last Post: 01-14-2007, 01:30 PM
  3. surface toolpath
    Last Post: 01-06-2007, 12:53 AM
  4. Replies: 10
    Last Post: 11-20-2006, 10:49 PM
  5. contour profile
    By stevieboy in forum Mastercam
    Last Post: 10-15-2003, 07:40 PM
