586,096 active members*
3,588 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Hardware > Water chiller - Tap Water vs Coolant Mix vs All Coolant
    Jun 2018
    18
    Hi guys,
    I just received my Chinese 80w laser with a cw5000 water chiller.
    The normal practice I found is to use distilled water but I can't get this in my country. Even if I find a seller, chances are its fake (just tap water)
    Should I use just tap water with a vehicle coolant (pink)?
    Or can I just use pure vehicle coolant (the pink one) will this work better?
    I'm particularly worried about rust which I read is an issue with these cw5000.
    Is there anything to consider with using pure coolant and should it be the pink or blue one?
    Thanks guys
    Oct 2011
    69
    Re: Water chiller - Tap Water vs Coolant Mix vs All Coolant
    if you can get rv coolant
  1. Distilled Water for Coolant?
    By brow318 in forum Tormach Personal CNC Mill
    Last Post: 06-26-2013, 12:21 AM
  2. RO DI Water with Coolant
    By SDS510 in forum Haas Mills
    Last Post: 10-08-2011, 02:16 AM
  3. How to control the water coolant by mach3?
    By Mongkol in forum Uncategorised MetalWorking Machines
    Last Post: 11-17-2010, 10:06 PM
  4. Water Based Coolant
    By classictom in forum MetalWork Discussion
    Last Post: 08-27-2008, 12:04 AM
  5. Coolant, mixing in more water
    By smellyfeet in forum Uncategorised MetalWorking Machines
    Last Post: 06-30-2008, 12:39 PM
