586,094 active members*
3,709 visitors online*
    CO2 Laser Bodor
    Hi there, I am really happy to found this forum. I am new to CO2 laser and i have been struggling trying to cut foam with it. I have a Bodor laser CO2 100W chinese model i am trying to cut open cell foam but i have not been able to find the right parameters to do so. I have also been thinking on getting a different nozzle to help me but i dont know what type of nozzles are appropriate for foam materials with thicknesses ranging from 10 mm to 30mm. Please if anyone has used a co2 laser to cut foam advise what parameters or nozzzle types to be used.
    Thanks a lot.
    Julian
    Aug 2016
    75
    Re: CO2 Laser Bodor
    I think it is going to be less about the nozzle and more about the focal length of the lens. If you have the standard 2" lens in your machine, a 4" lens might do a better job with the relatively thick foam due to the longer profile of the 4" beam's profile. Yes, you may need a new tube+lens+nozzle assembly.
    Often it is better to make multiple passes for each cut at a lower power versus trying to cut with just one pass at higher power.
    Consider cutting multiple layers of foam and then gluing them together versus cutting one really thick pieced of foam.
    The quality of the foam is important. Cheap stuff does not laser well and it falls apart/"sheds" after a short time.
    "80 Watt” 700mm x 500mm Ke Hui 7050 Laser (Similar to the Red Sail)
    Jul 2018
    The more focal lenght, the more depth of the cut focused. 2" focal lenght is appropiate for materials <10mm depth.
    Jul 2018
    Hello everyone I am new here.trying to get information on a Trumpf 3030 laser. Can anyone help?
  1. BODOR LASER- NOT A GOOD OPTION.
    By Imcclellan in forum BODOR Laser
    Last Post: 05-17-2022, 10:41 PM
  2. Anyone here have a Bodor laser cutter?
    By AdrianPage in forum BODOR Laser
    Last Post: 08-13-2020, 03:53 PM
  3. Review - Bodor Laser BCL1309XU
    By wwendorf in forum BODOR Laser
    Last Post: 08-16-2019, 01:52 AM
  4. CO2 150w Laser bed, Bodor Vs Camfive
    By litleboy in forum Polls
    Last Post: 06-08-2018, 07:36 PM
  5. Novakon/Bodor Laser Projects
    By iGAK in forum Commercial Laser
    Last Post: 04-25-2017, 06:39 PM
