586,116 active members*
3,274 visitors online*
Results 1 to 12 of 12
    Apr 2014
    11
    How Many Amps Needed
    How do you figure how much power a machine needs? will it always run at the same amp draw?
    I am retrofitting a MultiCam 1000 4'x8'.
    It has a 5hp spindle.
    2 6amp motors on X
    1 6amp motor on Y
    1 6amp motor on Z
    I am using Gecko Drives
    A PMDX 126.
    I am very new at this game. Will i set Mach 4 so that it never "lugs down"
    Thanks for now!
    Todd
    Feb 2007
    4553
    Post Re: How Many Amps Needed
    Todd,
    You did not mention if you are using stepper or servo motors however as a rule of thumb Gecko suggests 2/3 of the motors combined amperage .
    If you have stepper motors on all four axis that would equate to a (16) sixteen amp power supply.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Apr 2014
    11
    Ok thanks that makes sense. I must have missed that reading the gecko manual.
    Sent from my Moto Z (2) using Tapatalk
    Jun 2011
    692
    Do you mean power from the wall outlet or just sizing a power supply for the axis motors?
    Power from the wall, I'd say 30A minimum @ 240V. 50A would be safer.
    Apr 2014
    11
    Yes from the wall is what I meant. I should have been cleared on that. Also if someone could point to threads where people have worked on similar machines that would be great.
    Jun 2010
    4256
    Not one person in a thousand will ever draw full power on all their motors at once.
    I would suggest, very roughly, that you are unlikely to ever draw more than 5 kW in normal operation.
    Cheers
    Roger
    15362
    Quote Originally Posted by Toddler View Post
    The average machine like this running on 240v NA supply will need a 30 amp minimum supply at 240v, a larger supply if you have it, is always better, the 5Hp spindle can use up 20amps when run on single phase, at startup and working hard
    Mactec54
    15362
    Quote Originally Posted by RCaffin View Post
    Cheers
    Roger
    You are forgetting about the 5Hp spindle, being run single phase 240v the VFD Drive needs up to 2/3 more input than output
    Mactec54
    Jun 2010
    4256
    Could be a good argument for getting 3-phase from the grid installed (NOT from a rotary convertor!).
    Cheers
    Roger
    Apr 2014
    11
    Yes that'd be great. It is only a quarter mile away but it would be all on my land so I don't think it'd be free..
    Thanks for all the input!!!
    Jun 2010
    4256
    Not free, I am sure, but have you had it costed?
    I got a neighbour with a little backhoe to help me dig a ditch, then I laid conduit and 60 A 3-phase cable in it, and got the grid people to hook it up at the pole. I filled the ditch. The cost was not big, and infinitely worth it, and it is fire-proof. (I live on a farm.)
    Cheers
    Roger
    Jun 2011
    692
    In the US, getting 3 phase power typically is a couple thousand $ for the install, and I think 'commercial' power ends up more expensive monthly as well.
    It is a concern though, if it's only a 5 HP VFD, running on single phase will likely derate it to somewhere between 2 and 3 HP. If you need to run the spindle at 5 HP on single phase, you will likely need at least a 10 HP VFD.
  1. 600 Volts 20 Amps 3 Phase Needed
    By will_eng in forum Phase Converters
    Last Post: 02-15-2012, 05:52 AM
  2. low amps
    By gaffa in forum CNC Machine Related Electronics
    Last Post: 03-03-2009, 05:50 AM
  3. 2.5 amps per phase drive - 2.8 amps per phase bipolar motor ...
    By kochevnik in forum Stepper Motors / Drives
    Last Post: 10-23-2006, 04:48 AM
  4. How many amps needed for my bipolar stepper?
    By txcowdog in forum Stepper Motors / Drives
    Last Post: 03-25-2006, 06:23 PM
  5. Howto find input amps, from output amps on transformer?
    By sendkeys in forum CNC Machine Related Electronics
    Last Post: 07-15-2004, 01:13 AM
