588,550 active members*
4,915 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Connecting Mesa 7i83 for analog control of a servo.
    Nov 2005
    222
    I'm trying to control a DYN4 1.8kw servo being used as a spindle motor via analog -+10v. I have a Mesa 5i25+7i76+7i83 running under LinuxCNC. I have 24v field power connected to the 7i83 and I have this connection in the HAL and I and see the value on the hm2_5i25.0.7i83.0.1.analogout0 pin the HAL watch but I am not measuring any voltage above .3mv on the AGND and AOUT pins (3 & 4).
    net spindle-output => hm2_5i25.0.7i83.0.1.analogout0
    I thought all I would need to do is to hook the 7i83 AGND to the DYN4 AIN- and the 7i83 AOUT to the DYN4 AIN+. But before I actually made the connection I thought I would check the voltage and I'm not reading anything. Any ideas?
    John
    Nov 2005
    222
    Re: Connecting Mesa 7i83 for analog control of a servo.
    I made a little progress. I had to set the ENA+ high and now I get a fixed 10v. I think this is looking more like a software setup issue.
    Nov 2005
    222
    Making more progress. I changed the HAL entry to this:
    net spindle-vel-cmd-rps => hm2_5i25.0.7i83.0.1.analogout0
    I now get variable voltage values both positive and negative although the step seem a bit course. I think I'm on the right track now.
  1. poblem connecting servo drive to mach3 motion control
    By qussai in forum Servo Motors / Drives
    Last Post: 06-26-2016, 06:38 AM
  2. How to get Encoder readings and change analog output using Mesa 5i20 + 7i33?
    By Shen Bingquan in forum LinuxCNC (formerly EMC2)
    Last Post: 10-04-2010, 05:58 AM
  3. Can a AC Analog Servo drive be in MACH-3 control?
    By gurukrupaelec in forum Mach Software (ArtSoft software)
    Last Post: 06-12-2010, 11:59 AM
  4. servo drive position control by analog 0-10Vdc or 4-20Ma
    By rai in forum Servo Motors / Drives
    Last Post: 01-09-2010, 05:11 PM
  5. connecting 4-20mA device to analog input
    By Karl_T in forum CamSoft Products
    Last Post: 09-02-2006, 06:52 PM
