586,080 active members*
3,798 visitors online*
    Oct 2007
    1025
    bodor laser 150 watt
    I just purchased a bodor laser but not straight from china, I cannot do this I don't trust them after payment.
    I went through a dealer and so far I am happy with it.
    Small design things are irritating like the compressor is good but they reduced the tubing 3x down to an 1/8 at the head, even have a valve at the head why I'm not sure
    because with the reduced air flow you leave it wide open.
    Also the exhaust path...there fan is a good size but they are drawing from the top behind the gantry and smoke or small pieces can fall through onto the z axis drives and belts
    so there needs to be a barrier there ,They should also have fabricated a vent deflector where the air is drawn in but I can add that
    I am going to have to make some changes as I have an older 100watt that has no issues but its 2008 and I thought 2018 would bring new better designs or changes but
    it did not.
    The machine is well built and I also have the 5200 cooler
    Jun 2006
    3063
    Re: bodor laser 150 watt
    Some manufacturers put a ball valve in the air assist line just before it enters the nozzle so that the operator can moderate the flow rate a bit.
    Oct 2007
    1025
    yes that's right but the reduction in air flow you would not touch that valve , my old 100watt is the same dia tubing from the compressor to the head and there is no valve and a good air flow
  1. CO2 Laser Bodor
    By julianjaimes1985 in forum Laser Hardware
    Last Post: 07-24-2018, 10:02 AM
  2. BODOR CO2 150Watt/60 Watt
    By chirssinz in forum BODOR Laser
    Last Post: 02-06-2016, 04:29 PM
  3. Replace 30 watt C series epilog laser with 60/55 watt C series tube
    By jrich in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 03-25-2014, 07:00 PM
