603,940 active members*
2,177 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Hurco KM3 BELT CHANGE
Results 1 to 20 of 20
Hybrid View
dave73 Hurco KM3 BELT CHANGE 08-06-2018, 09:45 AM
dave73 Re: Hurco KM3 BELT CHANGE 08-08-2018, 02:50 PM
dave73 Re: Hurco KM3 BELT CHANGE 08-08-2018, 03:47 PM
macdave73 Re: Hurco KM3 BELT CHANGE 03-17-2024, 06:25 PM
macdave73 Re: Hurco KM3 BELT CHANGE 03-17-2024, 06:42 PM
macdave73 Re: Hurco KM3 BELT CHANGE 03-17-2024, 09:29 PM
macdave73 Re: Hurco KM3 BELT CHANGE 03-17-2024, 09:26 PM
macdave73 Re: Hurco KM3 BELT CHANGE 03-17-2024, 09:52 PM
Rich Carlstedt Re: Hurco KM3 BELT CHANGE 03-27-2024, 07:52 PM
dave73 Re: Hurco KM3 BELT CHANGE 05-20-2024, 09:50 PM
dave73 Re: Hurco KM3 BELT CHANGE 05-20-2024, 10:38 PM
dave73 Re: Hurco KM3 BELT CHANGE 05-20-2024, 11:22 PM
    Apr 2009
    29
    Anybody done a variable speed belt change, and, bearing change on a Hurco KM3 head.
    I will put pictures up as I do it.
    First thing I did was to remove main motor at back of ram!
    .............disconnect wireing from motor box
    .............undo cap heads under motor on lower casting
    .............undo nut holding tensioner spring, carefully, lever brake on side to stop motor turning
    Wireing, note wire positions ...........
    U
    Bottom Plate x 3 cap heads........
    Lever Brake on to stop motor turning .......
    Undo nut, watch for spring?...... keeping brake on!
    Undo cap heads holding motor....... remove
    Check the Nylon Splined Bush, any excessive wear, change if possible.
    Attached Thumbnails Attached Thumbnails 11049224-296B-4668-9A98-6C6F1102936A.jpg   31688F99-BF9C-488D-B5F1-75BB05FDA006.jpg   BFC5D369-006B-4977-93F8-1887A5C4EB4C.jpg   79956F81-D5F0-479F-A19E-0676B87FC5F6.jpg
    Apr 2009
    29
    .............disconnect wireing from motor box, making a note of where they go!
    Apr 2009
    29
    Next, while holding the brake on, using a socket undo the nut holding the tension spring on.
    Obviously, undo while keeping the pressure on
    Mar 2024
    12
    I initially took the Head off before undoing the Spring, better to undo spring with Head still on as above.
    Then removed the brake solenoid using a 10mm spanner
    Mar 2024
    12
    Found this document online somewhere, it says put the spindle to max speed, unfortunately my machine was'nt working when I got it so I could'nt do that anyway.
    I have already removed the Spindle motor cover and Spindle Motor, left the belt.
    Mar 2024
    12
    Mar 2024
    12
    I Have tried to put the pictures in some sort of order, but it was removed a while ago, so check as you go along.
    took a picture of the chain length to remind me how long it was, so that it goes beck the same.
    Mar 2024
    12
    Mar 2024
    12
    I removed nut and measured it, just in case?
    Feb 2006
    191
    Thank You MacDave 73
    Appreciate the magnificent work and pictures !
    rich
    Apr 2009
    29
    looks better after a clean up, next renew bearings and bushes
    Change Bearing on front Variable disk
    Next remove the Nylon Bushes from the front Variable disk and the back motor disk
    Apr 2009
    29
    Get the front drive shaft back into the Variable disk, take care not to damage the bearing, I made up some bushes and 1/2" rod.
    Apr 2009
    29
    Now to the Bushes, here's my drawing of the bush, now let me point out, this drawing has been altered to accommodate the bad tolerance which you get from 3D printing, in other words I have modified the drawing of the spline so that when I got the part 3D printed, I was able to make adjustments to the size, lathe turn and fettle/file.
    I did ask Hurco service if they had any old stock, of course they haven't, they did say however they thought there was a firm in the US where you could have them made for $300 , not sure if that was each or the pair. So I thought I would go down the 3D Printing route.
    Now, as most probably know, the concerns with 3D printing is Materials and Tolerance quality. Finding a suitable material appears to be trial and error, recommendation obviously is a good idea, tolerance however appears to be at best 0.3mm/0.012", that's huge and not very good. The other alternative is get a Broach made up - punch and die, this of course would be quite expensive, I reckon £750 +/- a chunk, $950.
    Apr 2009
    29
    I tried 3D printed parts in ABS, but it was so hard, I thought it would be too brittle, so I discounted that. After some search on the web I found a company who were printing a Nylon substitute, HP PA12. I was told it was similar to an Injection Moulded Part in spec, I was specifically interested in wear, friction, temperature.
    Hers a comparison sheet I came up with to try and compare Nylon with 3D printed material.
    Bushes Printed, modified and fitted.
    Attached Thumbnails Attached Thumbnails Comparisons 3DPA12_Nylon6_Nylon12.jpg
  1. Belt Change Help
    By MFchief in forum Tormach Personal CNC Mill
    Last Post: 04-12-2015, 04:51 AM
  2. A20 Citizen guide bushing belt change
    By Rittpuck in forum CNC Swiss Screw Machines
    Last Post: 11-15-2013, 05:10 AM
  3. need to change belt on hardinge vmc 1000
    By ikneb in forum Bridgeport / Hardinge Mills
    Last Post: 06-03-2013, 07:12 PM
  4. Spindle orient oi-mb after belt change
    By MidniteOil in forum Fanuc
    Last Post: 09-10-2011, 12:52 PM
  5. 6'' Craftsman lathe belt change
    By Rusty Knuckles in forum Want To Buy...Need help!
    Last Post: 02-11-2011, 02:27 PM
