586,089 active members*
3,820 visitors online*
    Aug 2018
    Sealing cones
    Hi!
    We have a problem with hardened sealing inner cones. Before hardening the cones, they are being machined in tolerances. After hardening, the form of the cones change radically.
    We haven't found solution for fast and effective way to make cones symmetric and sealing again. At the moment the only solution has been machining the cones with ballnose endmill.
    This solution has been very slow and we need some ideas to make cones more effectively.
    Thanks!
    Jun 2015
    4154
    Re: Sealing cones
    hi / pls share an image with the part, maybe the drawing too, and show the location where the problem is
    i can't figure it out only after reading your post / kindly
    Mar 2017
    314
    Re: Sealing cones
    I have made many hundreds of sets of close tolerance tapered pins and bushings for molds. Process = "Rough" turn (parts were held to a close tolerance here, just with extra stock) - send to heat treat - finish turn.
  1. RFQ: Lathe Work - Cones
    By MadGumby in forum North America RFQ's
    Last Post: 04-01-2019, 05:53 PM
  2. Rolling Cones, k factor
    By mattpatt in forum Solidworks
    Last Post: 06-07-2012, 04:58 AM
  3. RFQ steel cones needed
    By AustinT in forum Employment Opportunity
    Last Post: 11-09-2010, 06:55 AM
  4. Auto changers and Cones.
    By baldusi in forum Benchtop Machines
    Last Post: 09-22-2006, 07:05 AM
  5. Auto changers and Cones.
    By baldusi in forum Charter Oak Automation Support Forum
    Last Post: 10-21-2005, 05:10 AM
